trans problem
Old Jun 1, 2008 | 10:03 PM
boostking's Avatar
trans problem
I installed a new centerforce clutch and flywheel. after the install the pedal to me was soft but the clutch was bleed a number of times. the veh. now is hard to shift gears. it doesn't grind but it just doesn't seem to want to go. aside from that I broke the clutch in and took the car to the track. my brand new less than 1000 miles clutch slips! I will be calling centerforce because this df series clutch is junk! anyone have an idea as to why the car is now hard to shift and the clutch is slipping.
Old Jun 4, 2008 | 06:30 AM
tim0shel's Avatar
I have had two Centerforce clutches in other cars and the stock clutch had a harder feel and griped harder than the centerforce. I think the first time it was installed it got some oil on it and glazed but the second one i know was installed right and it slipped also not as bad but it did. so the last 4 trans i did in that car i used stock and had no problems with it. Just the spider gear pin breaking and putting holes in the bellhousing.
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
