"P-47 Start Up" ... and some complain if our cars don't start up right away!
(taken verbatim from vid)
Pre Take-Off and Cockpit Check
- Trim Tab Controls (test for movement)
- Throttle ... Closed
- Prop Control ... Full Forward
- Mixture Idle Cut Off ... Off
- Master Battery Switch ... Off
- Instruments ... Checked and Set
Ready Set To Take Off
- Elevator ... Neutral
- Aileron ... In Neutral
- Emergency Hydraulic Hand Pump ... Test For Pressure
- Cal Flaps ... Are Opened
- Primer ... Closed and Locked
- Throttle ... At 1 inch
- Battery ... On
- Starter Switch ... Clear
- "1, 2, 3 ... and Starting."
Geesh. I got tired after "Throttle ... Closed".
Turbo Johnny
Feb 21, 2019 09:41 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
