Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Racing Fuel....?
Old Aug 20, 2008 | 01:15 PM
kissmySS08's Avatar
Racing Fuel....?
Sorry guys this may be in the wrong forum, but does anyone know any stations that offer 100+ Octane unleaded racing fuel in or around Grand Rapids, MI? There used to be a sunoco that sold 100 octane when i had my turbo Civic, but they have since discontinued it! Any help would be greatly appreciated!!!
Old Aug 20, 2008 | 01:18 PM
hatrickstu's Avatar
not sure about a gas station man, but nearly all tracks have race gas you can use. might see if you can get it from them
Old Aug 20, 2008 | 01:25 PM
krispy's Avatar
e85?
not good for the fuel system or the turbo though, it burns dirty
Old Aug 20, 2008 | 01:26 PM
hatrickstu's Avatar
you cant just switch over to ethanol, he is looking for 100+ octane regular unleaded fuel
Old Aug 20, 2008 | 01:27 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Van Manen Oil & Propane
0-305 Lake Michigan Drive
Grand Rapids, MI 49544
(616) 453-6344
They sell Sunoco 260 GT100.
Or try calling the number listed here:
http://www.bazellracefuels.com/RaceFuelMap.htm
I get Cam2 110oct in Toledo, OH at a Speedway Gas Station. You have to take a gas can with you because the hose isn't long enough to reach the car. $6/gal is what it was at last I was there.
Old Aug 20, 2008 | 01:32 PM
Omega_5's Avatar
Originally Posted by krispy
e85?
While your right, it may not be compatible with the fuel system... it actually does not burn dirty. It has almost the same emissions properties as gasoline.
Old Aug 20, 2008 | 04:23 PM
tambrico's Avatar
e85?
You can buy conversion kits though. And I'm pretty sure it burns just as clean, if not cleaner than regular gasoline.
Old Aug 20, 2008 | 04:40 PM
krispy's Avatar
I thought I had remembered seeing where the exhaust condensates (which are not related to emissions) were worse with E85. Prolonged use could (likely will) corrode the fuel system and damage the seals on cars not rated for it. The car should still run on E85, might have to enrich the fuel tables since it has a lower energy density.
Actually, if it lubricates worse than normal gasoline it could do some decent damage to the high pressure pump & injectors on the LNF application.
Probably would be easier to just find race gas lol, I just had heard of some other FI applications playing around w/ E85 because of the higher octane.
Doesn't methanol also effectively provide the same benefit of a fuel with increased octane?
Anyhoo, I'm still confused why this is in the hypermilling section.
Old Aug 20, 2008 | 04:43 PM
Jackalope's Avatar
I'm confused as to why someone would think they need 100 octain race fuel if they weren't running a 12.5 to 1 or higher compression engine. Its a waste of money.
Old Aug 20, 2008 | 04:52 PM
hatrickstu's Avatar
not if you can up the timing
Old Oct 15, 2008 | 05:56 PM
cmiller8006's Avatar
(616) 453-6344
at the speedway near my house it is the same price but it is leaded, its what iuse in my four wheeler
Old Oct 16, 2008 | 01:45 AM
Jackalope's Avatar
YES even if you can up your timing cause you hit a point where the cylinder temps are tooooo high and you cause damage to the head or piston tops. My 1980 Turbo Trans Am melted its cylinder heads between the intake and exhaust ports on 100 octain Sunoco race fuel 10 degrees of timing and 24pounds of boost. It was UGLY!
Then I said **** tiny engines with turbos and went with the big block and never looked back. Ran low 11's for 10 years without ever having to pull a valve cover! BTW that started back in the early 90's when low 11 second daily driven street cars weren't a dime a dozen. All motor also with sreet tires thru the mufflers. I was trapping 142mph with well over 2.60 60" times due to MASIVE wheel spin.
Old Oct 16, 2008 | 05:06 AM
I was running 9's back then.
Old Oct 16, 2008 | 08:23 AM
Jackalope's Avatar
1/8th mile doesn't count.
Oct 27, 2015 01:27 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Cobalt_Daddy
Sep 27, 2015 06:59 PM
