Lap?
Old Oct 2, 2008 | 08:12 PM
pjk91's Avatar
Lap?
What is the LAP?
Old Oct 2, 2008 | 08:13 PM
JonyyB's Avatar
Site Founder
The LAP is a 2.2 L — 2189 cc (133.5 in3) — version of the Ecotec, based on the Gen II block.
Bore and stroke are 86 mm (3.4 in) and 94.6 mm (3.7 in), the same as the 2.2 L L61. Compression ratio is 10.0:1.
Major features that set it apart from the 2.2 L L61 are variable-valve-timing and other cylinder head improvements from the 2.4 L LE5.
Used In:
2009 Chevrolet Cobalt
155 hp (116 kW) @ 6100 rpm 150 lbˇft (203 Nˇm) @ 4900 rpm
2009 Pontiac G5
Info source: wikipedia
Old Oct 2, 2008 | 08:15 PM
Spanky's Monkey's Avatar
are there any around?
Old Oct 2, 2008 | 08:17 PM
JonyyB's Avatar
Site Founder
yes, all the 09 2.2's
Old Oct 2, 2008 | 08:33 PM
TurboTechRacing's Avatar
Very nice improvement! Base cobalt now have 155 ponies!
Old Oct 2, 2008 | 08:35 PM
ChevyRockstar's Avatar
MAKE A SECTION JONEL!!!!
all cap so your sensetive interwebz ears so you can hear lol
Old Oct 2, 2008 | 08:42 PM
pjk91's Avatar
so the le5 head is a better flowing head than the l61? what about the lsj?
Old Oct 2, 2008 | 09:10 PM
Thank You!
Old Oct 2, 2008 | 09:35 PM
JonyyB's Avatar
Site Founder
Um, the section was made hours ago...look what section the guy made the post in
that's why the guy made a thread asking what lap was...so I am confused by your post
Old Oct 2, 2008 | 09:37 PM
Originally Posted by JonyyB
Um, the section was made hours ago...that's why the guy made a thread asking what lap was...so I am confused by your post
i coulda swornm i saw it in the l61
awhile back i put a reaquest for this section .
Old Oct 2, 2008 | 11:54 PM
wardzach2007's Avatar
Request?
Old Oct 3, 2008 | 12:01 AM
FacelessKhaos's Avatar
Yeah i posted about it months ago....but it's good to see that it has it's very own section now. :-)
Old Oct 3, 2008 | 04:31 AM
kkanowitz's Avatar
Used In:
2009 Pontiac G5
hmm...so it's basically a 2.2L LE5 - I wonder if it has a different ECM? This could mean easy tuning in the future...
Old Oct 3, 2008 | 06:23 AM
HunterKiller89's Avatar
so, a gain of 7 hp, and a loss of 5 tq. Not very useful from a performance standpoint. however, i spose VVT gives it some more beathing options now, but now theres no cams for the 2.2 again! lol
Old Oct 3, 2008 | 03:34 PM
BoffDude's Avatar
vvt should improve gas mileage for stock, but a big deal with a boost app. you could run a cam-timer and have it open earlier for more power at the low end.
Old Oct 3, 2008 | 07:51 PM
Maven's Avatar
Yes, quite simply, the LAP is a 2.2L LE5. If you could put a 2.4 head onto an L61 youd what an LAP is.
The LAP and the LE5 share the same head and intake manifold, the LE5 has a lrger 65mm TB though, the LAP has the same ~60mm TB as the L61
Old Oct 3, 2008 | 10:40 PM
FryLoch's Avatar
Sweet first page in the first thread!!!!
Old Oct 4, 2008 | 01:17 AM
Maven's Avatar
Its not VTAK yo.
Old Oct 4, 2008 | 10:46 AM
pjk91's Avatar
Does the LE5 head flow more air than the LSJ head?
Old Oct 4, 2008 | 02:32 PM
Maven's Avatar
No, not to my knowledge. It does have different runner paths though. All 3 major head designs(LSJ/L61/LE5) have different designed runners But they all have the same sized valves, and very similar unported flow characteristics.
Old Oct 5, 2008 | 11:06 AM
BULLETSSMOKE's Avatar
im guessing this is the XFE engine?
Old Oct 5, 2008 | 01:09 PM
Yes and No.
The 08 early 09 XFE engines were still the L61 but they were "XFE" because they had different final drive ratios, different tires, and a slight adjustment to air/fuel mix to give it a mpg improvement of maybe 1-3 more than the reg L61. But now that the L61 is being phased out in favor of the LAP, the XFE Engine will be the LAP with a different final drive ratio and different stock tires.
Old Oct 6, 2008 | 02:03 PM
KyleMinnis's Avatar
nice the new balts are all gonna be quicker
Old Oct 6, 2008 | 03:22 PM
Maven's Avatar
Only as much as 7hp gain and 2 lb.ft LOSS can make you.
The LAP makes 2 less lbs of torque and its peak isnt until 4900(4200 for L61)
The one advantage the LAP has stock is that it has a broader flat torque curve, due to the VVT.
An L61 with a 2.4 Manifold will likely make them same/more horspower than the LAP, And the LAP has no "larger" manifold to upgrade to as it already uses the LE5 manifold, and since its still a 2.2 its just as likely that it wont benefit anymore from the larger 65mm TB than the L61 does(the LAP and L61 both have the same 60mm TB)
Id be very curious(am also slightly jealous) to see what an LAP will do with some LE5 cams in it. Maybe Ill trade up instead of a refi.
Old Oct 8, 2008 | 11:08 AM
nhanson's Avatar
im interested in how it does boost....cause i know the l61 is rated **** for peak horsepower....
