HID Ballast question
Old Oct 3, 2008 | 03:58 AM
G85 SS's Avatar
Before someone screams "search button" I did search around and for a while but came up empty handed. I am looking into getting the 6000K HID kit from 3B. I see that they offer 2 different wattage ballasts. One at 50 and the other at 35.
Am I correct in saying that all the higher wattage ballast does is cause the HID bulb to be brighter and lose some of it's color?
Thanks for the help..
Old Oct 3, 2008 | 08:44 AM
Mr McCabe's Avatar
I asked the same question to 3B Spec. and Yes it is brighter but you lose 1000k of colour. So if you buy 6000k lights then the colour with the 50watt ballasts will be 5000k.
Old Oct 3, 2008 | 09:35 AM
wardzach2007's Avatar
I say go with the lower wattage. But if you're going with visibilty, then go with the higher wattage. But higher wattage meands more heat in your housings. And right now with my housings, heat causes my heads to fog up after a car wash.
Old Oct 3, 2008 | 12:38 PM
Switt23's Avatar
That's not from heat... that's from poor sealing, moisture is getting inside.... very bad for bulbs!
Old Oct 3, 2008 | 07:38 PM
Actually its both. The heat causes my housings to heat up and fog everything up. So now all I do is make sure I turn off my auto lights before I go wash my car. Problem fixed.
And FYI, my bulbs are never affected by the moisture, they're behind the projector lens. So thanks for your two cents.
Old Oct 4, 2008 | 04:19 PM
G85 SS's Avatar
Thanks guys. I am going for visibility over looks with HID's so I don't really want a blue looking color and I will be going with the 6000K HID's.
And even with the 50 watt ballast they will still burn cooler than halogen bulbs, right?
Old Oct 5, 2008 | 01:11 PM
Heck yes!
Old Oct 5, 2008 | 06:57 PM
EmperorJJ1's Avatar
the fogs arent sealed thou are they?
Old Oct 5, 2008 | 07:19 PM
Not that I know of.
Old Oct 5, 2008 | 10:04 PM
Switt23's Avatar
Okie dokie . I'm just a dumb blonde from Nebraska who doesn't know anything.
Old Oct 5, 2008 | 10:09 PM
EmperorJJ1's Avatar
^^^ lol
Old Oct 5, 2008 | 10:34 PM
I didn't know you were a girl? Thanks for letting me know Steve.
brandon04
Oct 21, 2015 07:04 AM
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
