2.0 LSJ Engine: How to: Install OTTP Rotated Mount Stage 1
Old Feb 8, 2009 | 04:43 PM
recklessactn's Avatar
Never done a mount swap or install before and this took me about 45 mins in my garage with simple tools.
Step 1: Get together your OTTP stage 1 rotated mount setup, a 15 mm and a 18 mm socket, 3/8's drive socket ratchet, 3/8's drive 3 inch extension and some glue (optional, but not anything crazy like super gorilla glue). I'm missing one socket, the 3 inch extension and the glue bc these were all things I used when I started working and needed them.
Step 2: Jack up your car with jack stands or ramps and secure the rear wheels with wood or a brick to keep it from rolling back.
Step 3: Place your jack under your engine, supporting it with wood, and jack the engine up to where the front mount is almost level to the ground. You will also know it is at the right height because when you pull the bolts there will be less strain on them.
Step 4: There are three bolts to remove that require a 18mm socket to get them out, I took out the bolt in the rubber insert first then the ones in the tranny. Once you remove them take out the mount and then put in the OTTP mount. Bolt in the mount to the tranny first, then take the bolt that goes into the rubber insert and see if it lines up with the frame. If it doesn't adjust, then jack up or down to get the holes to line up (don't force it). Take the two washers and place one on each side of the rubber insert and slide the bolt through. Tighten all the bolts down and your done with the front mount.
Bolts circled in red are the ones you remove.
Step 5: Reposition the jack if needed (I didn't need to) and remove the three 18 mm bolts on the tranny(use the extension here for the top and middle bolts if needed). Then disconnect the O2 sensor harness (it makes it easier to maneuver the mount around).
The three bolts are circled in red as well as the o2 harness that is at the top of the mount and easily disconnected. Some of my photo was blocked by the wood I used but you can tell where the bolts are.
Step 6: Using a 15 mm socket remove the three bolts that hold the mount to the frame. After you remove these bolts, take your three hole shim and put a little bit of glue on it (optional..haha). The mount should be able to move around a bit, so lift up on it and line up the shim into the mounts notch that the bolts seat into. Place it in there and then sit the mount back down onto the frame. Re bolt the frame to the mount using the three bolts you just removed. Using one of the bolts you pulled from the tranny, insert it into the middle hole where you pulled it from the mount. If you can bolt this in then do so, if not adjust the jack up or down to get it to go in (don't force it). Insert the remaining two bolts left where you pulled them from.
Step 7: Drop the car and burn rubber!
Old Feb 8, 2009 | 05:24 PM
MarcS's Avatar
The Stig
Approved!
Old Feb 8, 2009 | 07:17 PM
red_line_cobalt's Avatar
nice! thanks!
Old Feb 8, 2009 | 07:18 PM
Black SS/SC 06's Avatar
good stuff reckless
Old Feb 8, 2009 | 07:41 PM
Maven's Avatar
The glue isnt for the keyhole spacer.
I glue the round washer type spacers to the front mount...that way you dont need to try and wiggle them in there are use multiple hand to put in the bolt.
Old Feb 8, 2009 | 08:45 PM
haha i actually got the round washers in there the first time but the keyhole was givin me problems lol
Old Feb 13, 2009 | 01:22 AM
ls1fbody's Avatar
Haz l33t wheelz.
good job man. didn't see this. now i'll know what to look for when i'm banging away under there.
Old Apr 6, 2009 | 02:29 AM
stkshkr's Avatar
Thanks, going to do mine tomorrow. Think I'll leave the poly mount in the rear.
Old Apr 6, 2009 | 02:05 PM
warrenb213's Avatar
and is wheel hop gone now?
Old Apr 6, 2009 | 02:23 PM
ebristol's Avatar
Here is a pic I took of the rear spacer with the mount.
Old Dec 13, 2009 | 05:01 PM
Got the front mount on. Spacer looks like it is a pain in the ass.
Old Dec 13, 2009 | 05:12 PM
thefishyisblue's Avatar
lol you so silly max.
Old Mar 18, 2010 | 09:11 PM
rallyracer's Avatar
It looks as if you jacked the engine up using the oil pan...maybe I'm just looking at the pic wrong.
Old Mar 18, 2010 | 10:55 PM
ls1fbody's Avatar
Haz l33t wheelz.
I jacked on the transmission, but what would be different if you jacked the engine?
Old Mar 19, 2010 | 11:51 PM
^ yes i used the oil pan but the tranny also works fine :-P little wood is needed though
Old Apr 14, 2010 | 07:35 PM
Unforgiv3n's Avatar
good stuff! Going to be installing mine tomorrow. Are there any other things I should be looking out for, besides those mentioned above?
Old Apr 14, 2010 | 08:32 PM
northvibe's Avatar
torq specs should be added and like on my car, loosen the upper passenger side mount (3bolts) by 3/4 a turn so the engine can move making installing the stage 1 mount WAY easier. Me and rally had to use a prybar until John told us to do that.
Old Jul 8, 2010 | 11:36 PM
Brenticus's Avatar
cool. sub'd.
Old Oct 1, 2010 | 03:57 PM
Brenticus's Avatar
you might want to add that you need to loosen the three bolts on the upper engine mount by one turn after this is done and then retighten. this realigns everything. i still had wheel hop after install, but then i was informed of that detail and it took it all out completely.
Old Oct 5, 2010 | 05:50 PM
can't edit it :-(
Old Dec 3, 2010 | 07:54 PM
ddawg23213's Avatar
does anyone have torque specs for any of this stuff? mainly the engine mount.
Old Dec 3, 2010 | 10:39 PM
Originally Posted by recklessactn
can't edit it :-(
I can
Let me know what needs to be changed.
Old Dec 3, 2010 | 10:41 PM
https://www.cobaltss.net/forums/driv...mounts-100338/
Old Dec 6, 2010 | 01:16 AM
PenguinPIE's Avatar
so after putting in the mount and the spacer, just drop the car, loosen and re-tighten the 3 bolts on the upper engine mount?
Old Dec 6, 2010 | 11:35 AM
neumannl001's Avatar
very cool!! thank you.
