2.0 LSJ Engine: How to: Install OTTP Rotated Mount Stage 1
Old Mar 2, 2011 | 06:08 PM
CleanCut's Avatar
i know this is prob gonna get me some heat but its not shown in here which way the front mount is installed, as in what side is facing up since i havent gotten under the car to check it out yet.. anybody?
Old Mar 2, 2011 | 07:12 PM
1fastSSBalt's Avatar
Check under the car and FACEPALM! It does only go on one way though(that last comment was jokingly). It is pretty straight forward just follow everything and do it right.
Old Mar 3, 2011 | 12:09 AM
CleanCut's Avatar
yea thats what i was thinking.. im not gonna get butt hurt like 90% of the people on here
Old Mar 3, 2011 | 12:20 AM
Blown07SS's Avatar
Subed for this week
Subed for this weekend
Old Mar 24, 2011 | 08:12 PM
iwishidroveaneon's Avatar
its not completely necessary to take the rear mount all the way off. you can just loosen the bolts and slide the spacer in there this way you dont have to deal with trying to line everything back up which was a pita for me
Old Apr 5, 2011 | 07:33 PM
NexTnmE's Avatar
I did the front mount first, rear mount spacer second, lowered the car back down, loosened three upper motor mount bolts a turn, drove back and fourth in my parking space a few times, tightened... still getting wheel hop as bad as stock...
Actually, I have loosened the three bolts, on three occasions now, and still wont cure my hop. I've got Goodyear Eagle F1's (GS-D3) with about 38 psi in all.
HELP!
Old Apr 5, 2011 | 08:43 PM
08SStc's Avatar
did you try lowering the PSI, 38psi seems alil high
Old Apr 5, 2011 | 09:08 PM
cbro's Avatar
i had a little wheel hop still but wasnt as close as stock was.
Old Apr 6, 2011 | 01:17 AM
Brenticus's Avatar
Loosen each bolt on the engine mount found under the hood on the passenger side by one full rotation and then retighten. i had that problem and someone told me this. works like a charm.
Old Apr 6, 2011 | 11:14 PM
cbro's Avatar
did that and works fantastic.
Old Apr 8, 2011 | 05:49 PM
  #36
Brenticus's Avatar
i know. you really wouldn't think so, but it sure does!
Old May 12, 2011 | 12:09 PM
  #37
07SportRedSS's Avatar
so can you install the front mount and rear shim and then loosen the mount and then tighten it? or do you loosen the engine mount bolts before installing the front mount??
Old May 12, 2011 | 12:16 PM
  #38
NexTnmE's Avatar
Me and CTcar did this a few weeks ago: support the engine at all times... 1) we loosened the upper mount, 2) replaced the front, 3) added the shim in the rear, 4) drove the car back and fourth in the drive way two times, 5) tightened the upper.
Bada bing, bada boom!
Old May 12, 2011 | 12:51 PM
  #39
thank you man.. so you leave the engine mount loose and put the car in gear a few times then tighten it back up?
Old May 12, 2011 | 01:01 PM
  #40
NexTnmE's Avatar
Yes. The upper mount was loose from beginning to end. By loose i mean about three turns of the bolts...
Old May 12, 2011 | 04:13 PM
  #41
well i'm finished with the mounts and i officially have wheel spin instead of wheel hop (:
great write up and info.. thank you guys
Old May 19, 2011 | 11:15 AM
  #42
PenguinPIE's Avatar
I just had the mount put in and I get some strong vibration at idle but it is smooth when rpm is over 1k. Is this normal?
Old May 19, 2011 | 02:47 PM
  #43
yea it should vibrate like that
Old May 19, 2011 | 04:17 PM
  #44
PenguinPIE's Avatar
oh, hopefully the vibs get weaker over time.... it might drive me nuts one day lol
Old May 19, 2011 | 10:19 PM
  #45
you get used to it after a few days its not too bad
Old May 25, 2011 | 09:05 PM
  #46
CleanCut's Avatar
So i just installed mine today after a long while of it sitting in my trunk and it feels good on there... only thing is the engine vibrations are kinda annoying while the car is at idle.. any quick fixes? and yes i loosend the top motor mount and re tightened it when i was done and still vibrates
Old May 26, 2011 | 01:27 AM
  #47
cbro's Avatar
it will always viibrate due to the different mounts. just have to get used to it
Old May 26, 2011 | 04:59 PM
  #48
CleanCut's Avatar
its not so annoying anymore today.. the benefit of the crisper shifts and less play on the motor outweighs the vibrations at idle
Old May 26, 2011 | 09:35 PM
  #49
PenguinPIE's Avatar
i still cant stand the vib.. the steering wheel rumbles too much at idle and the whole car feels much older than it is.
I might consider switching to gmpp mounts
Old May 30, 2011 | 10:25 PM
  #50
origami78's Avatar
Thank you for the write up. I just installed mine today. It took about 30 min and that includes getting the tools out and putting them back up. I usually only have wheel hop when it rains so I will test it then. I have to say I did notice some vibrations I should get use to that.
