Dezod Motorsports Dezod Motorsports Is a Supporting Vendor of CobaltSS.net
contacts: Dezod
Aem Uego Sale
Old Mar 3, 2009 | 11:23 AM
Dezod's Avatar
Aem Uego Sale
AEM UEGO Controller-Air/Fuel Ratio or Lambda (6 in 1 Gauge-Type; Sensor Included)
(Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!)
"SIX-IN-ONE GAUGE-TYPE UEGO CONTROLLER"
24 Color-coded LED display lights provide immediate reference to engine¬タルs air/fuel ratio (AFR) or Lambda (11.0:1 to 17.0:1)
Integrated three-digit display reveals AFR or Lambda in real time (10.0:1 to 18.5:1)
User-selectable 0-5v analog output included for use with data loggers and most programmable engine management systems
NEW! Switch between AFR or Lambda readout with a twist of a switch (included face plate change is required for proper readout)
NEW! Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!
NEW! Quick-Connect system eases installation by allowing users to mount the gauge and sensor wiring separately
Ideal AFR monitoring tool for carbureted applications and engine dynamometers
Does not oscillate AFR like narrow band sensors
Serial data stream included for output of AFR (RS 232)
Accurate to 0.1 AFR
Bosch UEGO sensor included
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
Stuff
Oct 1, 2015 05:47 PM
yellow dragon
Sep 28, 2015 09:49 PM
