Off Road DP Question
Old Mar 14, 2009 | 07:02 PM
steven6870's Avatar
Simple question. If you install an off-road downpipe say from Hahn or CIA, will it through a CEL code? Or do you need to install a catted one? Thanks in advance.
Old Mar 14, 2009 | 07:05 PM
glhs379's Avatar
no cel from the hahn one
i have had it on for miles and miles and no code
Old Mar 14, 2009 | 07:45 PM
FakeWhiteMan's Avatar
If you don't mine me asking, how loud is it? How about the sound?
I have the dejon sri and I'm debating on ordering the catless DP from hahn tomorrow, i just need to be sure its not super ricey loud....
Old Mar 14, 2009 | 08:49 PM
TurboTechRacing's Avatar
No CEL from the Hahn non catted DP
Old Mar 14, 2009 | 11:43 PM
glhs379's Avatar
i like it with the stock catback
not ricey at all, very deep tone
a little raspy when you first jump on it
go with the hahn, great product, you won't be dissapointed
Old Mar 15, 2009 | 12:26 AM
Zander916's Avatar
Is it hard to do yourself?
I'd more likely just want to take it somewhere but is it difficult to get a shop to do it since it's "offroad use only"?
Old Mar 15, 2009 | 09:10 AM
glhs379's Avatar
not hard at all with a 15mm socket, 15mm wrench and a woble ext
they make a special socket to take off the o2 sensor, i have one and hate it
i use a small pipe wrench and it came off real easy
prob take 30 mins or so on jack stands
Old Mar 15, 2009 | 01:44 PM
fredds-turbaltSS's Avatar
anyone no if the CIA catless DP throws a code?
Old Mar 15, 2009 | 03:37 PM
glhs379's Avatar
the CIA seems to have the same o2 sensor chamber that hahn originally came up with so i am sure it does them same
Old Mar 15, 2009 | 04:20 PM
umrdyldo's Avatar
They are very similar. I think the only difference is the location of the cat
Old Mar 15, 2009 | 04:26 PM
JimzSS's Avatar
without a cat 99% sure you will get a cel, unless the engine puts out very few HCs and NOs, which is unlikely.
the rear o2 tells the ecm that the convertor is working
Old Mar 15, 2009 | 05:25 PM
ClearImageAuto Dan's Avatar
No codes, as the O2 sensor "chamber", as it has been called, basically fools the pcm. It's an idea which has been used for many years by many companies for many different cars. It just seems new to the Cobalt community.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
grampss
Sep 27, 2015 08:51 PM
