Wheres the TVS dynos Or SLIPS
Old Mar 15, 2009 | 07:35 PM
zrated89's Avatar
alright guys i know a bunch of people got in on the group buy get ur lazy %$^** up and to the dyno or the track!!!!
Old Mar 15, 2009 | 08:36 PM
WickedSS2005's Avatar
it is march, tracks are just opening. the local one to me isn't opening until end of march on saturdays. Relax
Old Mar 15, 2009 | 08:52 PM
ssyellowss's Avatar
wicked if you're gonna head out to the track, send me a pm or something, i'd wanna go with.
Old Mar 15, 2009 | 09:48 PM
Ryze's Avatar
Only 7 people have received the TVS from the GB so far, Harrop is working on producing them..and a lot of people haven't paid for it totally yet
Old Mar 17, 2009 | 11:36 PM
zrated89's Avatar
gotcha
Old Mar 18, 2009 | 02:18 PM
SS/SCking's Avatar
Relax only 7 people including myself got them from the GB so far and some of us are in the middle of rebuilds.
Old Mar 18, 2009 | 02:26 PM
ralliartist's Avatar
M88ArRamadi 407 whp, 387 wtq I, TB, WI, TVS, 2.75, HE, DU, 60's, RS, FI, H, CD, E, RG (other mods: 10.5:1 diamond pistons, ported head)
just for information's sake, here's M88ArRamadi's tvs numbers. He put out more tq than paul (blackg85ss) and he did a 421whp pull, which is when the motor blew due to massive knock.
Old Mar 18, 2009 | 02:39 PM
hungryhip-ccp's Avatar
so are you saying he blew the 10.5 diamonds?
i have only seen that once before in person (ravenss) and that was du to like 20* KR
Old Mar 18, 2009 | 02:42 PM
Yea, his dyno sheet got real shaky up top. You could tell something was terribly wrong. It was a TON of knock. He's got a for sale thread now trying to get rid of the tvs.
victoryss's Avatar
there is hope for the TVS now
Old Mar 18, 2009 | 02:43 PM
yup yup. Those are pretty good numbers. But that's a on ported head, well, exhaust ports were ported.
Old Mar 18, 2009 | 02:48 PM
ChevyRockstar's Avatar
interesting to know
Old Mar 18, 2009 | 05:54 PM
HOT CARLS SS's Avatar
Nice numbers makes you wanta stay supercharged
Old Mar 18, 2009 | 06:04 PM
leviticus88's Avatar
Yikes! Just a bad bottom end build or tuning?
Old Mar 18, 2009 | 06:18 PM
StevesBlack06's Avatar
prob a bit of both. sounds like my last build. i sheared my rod bolts due to them being over torqued, plus i never had a tune worth a ****. bye bye to the bottom end. that was an expensive booboo. bent my stock rods when the crank hit em and shrapneled my diamond 9.5:1 cr pistons and blew a hole in my lower girttle and made 2 holes in the oil pan. exploded my starter as well. good times
Old Mar 18, 2009 | 07:00 PM
Deathscythe's Avatar
zrated, you're in the area and I'll be back in a month or so. Once I learn to drive the car again (...), we'll head out to the track. I know vmp is already open, but the weather isn't the best right now.
On m88, was he running out of fuel up top? I know the 60's are good and all, but with a base tune on my car, the 60's didn't have that much room to work with. His fueling might have been a cause with that, especially if he had a ported head and all
Old Mar 18, 2009 | 07:04 PM
slowswap's Avatar
I wonder what some C16 could do...
Old Mar 18, 2009 | 07:10 PM
Darkmanx's Avatar
well atleast someone broke 400s on the tvs .
Old Mar 18, 2009 | 07:15 PM
FastSSinNH's Avatar
Dude, you dont **** around when it comes to blowing your car up huh?
Old Mar 18, 2009 | 07:52 PM
SS/SCking's Avatar
Mmmm C16....
Old Mar 18, 2009 | 08:12 PM
INFE's Avatar
First off that guy did not make more Tq then paul and paul was on a stock motor and still is. I guess you dont know his other #s. O well
Old Mar 18, 2009 | 08:18 PM
Still some high numbers though. There'll be others coming along real soon putting up numbers like that.
Old Mar 18, 2009 | 08:28 PM
2. 06blackg85ss 414 whp, 378 wtq Verified Mustang dyno TK, DP, E, T, I, 60s
Looks like he put out more tq to me. 387 compared to 378. We all know that Paul has put down higher
numbers than this, but the point is, these are the numbers that Paul has officially posted. Big
turbos are known to make tq suffer slightly due to spool time.
Chill out.
As for M88ArRamadi, he wasn't running out of fuel. He had 60's with a return set up. He had tons of
knock issue due to mainly they extremely high compression and the amount of boost that the tvs was
pushing. He was on the stock cams. Had he been on aftermarket cams, I'm sure the knock issue
wouldn't have been as bad due to aftermarket cams lowering your compression ratio, but then his tq
would have suffered.
Point is, these numbers are really high. So it looks like there is hope. Just got to be a bit more
careful when putting stuff together. Personally, I don't think this was a well thought out build.
While his numbers are really high and make the TVS look great, running 10.5:1 pistons on stock cams
with a relatively small pulley on the TVS and daily driving is a bit insane. Had he been on stock
compression, his numbers might have suffered a bit, but the car might still be alive right now.
Point is, the numbers are high and are great, but for a DD car, a bit more conservative setup would
have lasted a lot longer.
Old Mar 18, 2009 | 08:32 PM
(exhales slowly) I think that's the only thing I overlooked when looking in his vbgarage. I know his build isn't much different than mine and I was wondering why he had so much knock. You even said he had a ported head (exhaust) so I'm still scratching my head. Once I get back, I'll have to go to a shop and find out what would be a good gring to mate to my tvs.
Old Mar 18, 2009 | 08:34 PM
Darkmanx's Avatar
When my tvs comes in ill dyno and tune it the same day just for you ok!
