Twm Short Shifter Indecision.......
Old Mar 29, 2009 | 03:15 AM
cresintern's Avatar
thinkin bout the twm short shifter kit for balt ss/tc , but i have been hearing mixed results from people. mostly on errors in installing it. is this a hack and cut kit, i don't want any of that. i looked at their online install manual, didn't show any hacking, but.....
just don't wanna screw anything up with my shifting and gear placement. can any skilled mechanic do this? takes an hour to do?
was it worth it, 4 those that have it for ss/tc?
wanted to get kit and bushings...
Old Mar 29, 2009 | 07:48 AM
ufnwish's Avatar
i did a b@m shifter in mine its not that bad took 45 mins or so the fun part is geting the clips lose with out breaking then lining them up on the rods in the same spot mark the rods with a marker as they are before you take them off the only prob i had was getting rev to line up
Old Mar 29, 2009 | 12:55 PM
xxxxsh4d0wxxxx's Avatar
It's so easy. The cutting part is literally nothing.
Anyone could do it.
Old Mar 29, 2009 | 12:58 PM
orbalt08's Avatar
I have it for my tc w/ upgraded bushings and weighted knob. This is NOT a hack kit. It is extremely easy to install and should take you less than an hour. The hardest part was taking the stock knob off. You will keep your gear placement if you adjust the cables correctly and are patient and not in a hurry. TWM is a great company and offers an amazing product!
Old Mar 29, 2009 | 01:04 PM
OBZ's Avatar
OBZ
TWM makes great products! I have had my short shifter on my 2.2 now for over 2.5 years with no issues! The cutting is just for extra clearance. And its all under the consol so its not visible
Old Mar 29, 2009 | 02:03 PM
orbalt08's Avatar
What are people having to cut on these shifters to make them work? I haven't heard of any of this
Old Mar 29, 2009 | 02:07 PM
desperado's Avatar
I just replaced the hurst shifter in my SS/sc with a TWM weighted knob setup with bushings. Shifter is top notch. There was a noticeable difference between the two shifters. The TWM is shorter, firmer, and the through is shorter. TWM shifter is one of the finest shifters I have seen and diffinetly saticfied with the upgrade. And long as you take your time and pay attention to the shifter linkage retainer adjustments, the install should be problem free, and gradifing.
Old Mar 29, 2009 | 09:46 PM
Dave7417's Avatar
I have the TWM with my 2.4 F23 trans. I assume the F35 is the same. You have to trim a small 1" x 1" section of webbing from the console interior to clear the linkage. It is a minor issue. Download the installation manual from the TWM website. It will be documented there.
Old Mar 29, 2009 | 10:06 PM
orbalt08's Avatar
Well he is asking about install instructions on the tc and i installed mine on my tc, and i didn't have to cut anything to get it to fit or work properly.
Old Mar 29, 2009 | 10:13 PM
BlueBolt66's Avatar
I installed my TWM STS with bushings on my S/C and it was a quick easy install and works great. I didn't have to do any cutting I think you only have to cut for the 2.2
Old Dec 28, 2009 | 06:17 PM
BlackSSNick's Avatar
What is the shifter linkage retainer adjustments?
Old Dec 28, 2009 | 06:23 PM
Marca34's Avatar
Best STS out there, i bought mine and the aluminum bushing and i think i spent no more than 30mins installing it. It comes with detailed directions. to me it was a waste to read them i just looked at the pictures.
Old Jan 5, 2010 | 03:52 PM
TWM Performance's Avatar
Just for the records, there is no cutting required for the Cobalt SS/TC short shifter. It's a pretty straight forward install.
Thanks for the feedback everyone!
Frank
TWM Performance
Old Jan 5, 2010 | 09:13 PM
K0ba1t 5s's Avatar
twm shifter r really good and easy on installs, ive installed all types of shifters, and theyve been the easiest, no offence but any one who has a prob with installing this shifter is kind of dur dur dur, its really easy
id recomend it highly
Old Jan 6, 2010 | 01:06 AM
87gn06gto07irl's Avatar
No complaints with mine. No cutting required on Redlines.
Old Jan 6, 2010 | 01:12 AM
WVsuperSS's Avatar
i was starting to worry about cutting, never had to cut mine... and it truly is a great STS
biniecki
Oct 25, 2015 02:23 PM
footballplaya3k
Sep 30, 2015 09:39 PM
Cptnslo
Sep 24, 2015 09:32 AM
ashalle2
Sep 16, 2015 10:36 PM
SS_2009_TC
Sep 11, 2015 05:41 PM
