Flat spot with TVS
Old Apr 19, 2009 | 01:04 PM
ArielAtom's Avatar
Flat spot with TVS
I just dyno'd my car on Tuesday the 14th. I made 315 whp, but, I had a major change in slope at 6000 rpm. The hp to rpm rose steadily until 6000 where it broke sharply and continued to rise slowly from there. Is this a typical TVS trait or is this something more specific to my car?
My Atom uses a straight through 3" exhaust that terminates to Supertrapps. The Supertrapps had 10 wafers a piece on them. After the dyno several fingers pointed to the Supertrapps, unfortunately to late for that session. Other than the exhaust, I think that all other items are very similar to what you guys are using in your Cobalt's. 2.0L LSJ, LS4 TB, 60 lb injectors, return style fueling, valve springs, K&N cone filter with about 18" straight pipe to LS4
If this a typical trait, I will quit wasting time to find the anomaly and go straight into the head and cams using tried and true better breathing techniques.
Specifics as to what I am doing are in the thread "Dyno for a Harrop in an Ariel ", response 86 refers to the dyno https://www.cobaltss.net/forums/show...=157228&page=5
Old Apr 19, 2009 | 01:09 PM
red06SC's Avatar
Oh hi, just stepping in to say
TVS Atom? fapfapfapfapfapfapfapfapfapfapfapfapfapfapfapfapfa pfapfapfap
Old Apr 19, 2009 | 02:19 PM
blackbolt89's Avatar
omg. that car must FLY
Old Apr 19, 2009 | 02:23 PM
qwikredline's Avatar
#1. Supertrapps are deadly take them off and attenuate noise differently.
#2 forget the LS4 tb,
#3 fix the exhaust ports in the head
#4 make sure you have the right injectors and PM area47 to tune
#5 q.e.d. Fixed
Old Apr 19, 2009 | 02:25 PM
victoryss's Avatar
If you could please post a copy of the dyno sheet so I can see it. FYI though 315whp is about average on a bolt-on lsj with an average tuner. Porting the Head is where you will see a HUGE gain.(did i mention HUGE)
#5 q.e.d. Fixed
winner winner chicken dinner
Old Apr 19, 2009 | 05:33 PM
leviticus88's Avatar
Ditch the supertrapps, port and polish the head.
That car is bad ass! Congrats!
Old Apr 19, 2009 | 07:29 PM
TVS_SS's Avatar
are you using the lsj computer? did you ensure the boost control solenoid is not active? What happens to mass airflow, spark timing, and boost?
Old Apr 19, 2009 | 08:22 PM
ArielAtom's Avatar
#5 q.e.d. Fixed
#1 My first experience with Supertrapps on anything that moves a lot of air. I had a PM from someone that track races an Atom and he stated that he is running at least 23 not 10. If I take them completely off, the car is just to loud. Do you know of another attenuation option?
#2 My tuner will be over on Tuesday to fix my drive ability issues, but, I am about ready to take it and drive over it many, many times
#3 I am going to do a fully ported head and just switch them at some point
#4 I have 60 ib injectors and was unaware that Area did mail order tunes
#5 Maybe I am being dense, but, I don't know what you mean here.
Thanks
Yes, we are using the LSJ computer. I am not the tuner, so, I will ask on your other three questions, I can answer that boost remains consistent at 22 lb and that nothing radical is happening with timing
Old Apr 19, 2009 | 08:30 PM
ls1fbody's Avatar
Haz l33t wheelz.
John, why don't you like the LS4 TB? you have to set the scalar pretty high but it's not that bad...
Old Apr 19, 2009 | 08:36 PM
Darkmanx's Avatar
What pulley are you running?
Old Apr 19, 2009 | 08:42 PM
Thanks
Ok for the head just port the exhaust, for noise attenuation I recommend a cat, the longest resonator/diameter you can package and a Corsa Daytona Prototype muffler and a turn down at the tail pipe....the injectors are okay and I now (after some work here) can say I consider area47 the most awesome of tuners, and for $ he will (maybe) work for you
'Q.E.D.'= Quad Erat Demostratum. : "That which is demonstrated"....goes at the end of every succesful solved equation...
s**t. cant spell it any other way. And the power it adds ? not worth pouring milk on that cereal....
Last edited by qwikredline; Apr 19, 2009 at 08:42 PM. Reason: Automerged Doublepost
Old Apr 19, 2009 | 09:10 PM
ArielAtom's Avatar
80 mm
Good information .... Thank you!
Old Apr 19, 2009 | 09:54 PM
ls1fbody's Avatar
Haz l33t wheelz.
from what i've seen it adds anywhere from 7-11 hp al across the powerband. I'll have to get some before and after pulls to really see for myself.
Old Apr 19, 2009 | 10:35 PM
just do it and drive it for a couple of days. then you will take it out and someone else will buy it and the circle jerk will continue
Old Apr 19, 2009 | 10:37 PM
ls1fbody's Avatar
Haz l33t wheelz.
hahah, ok John. now i know why you don't like it.
Old Apr 20, 2009 | 12:28 AM
ArielAtom's Avatar
I haven't given up on it yet, but, just imagine it in a 1350+/- lb car! The little hiccups slam you in the seat and make you look really talented as a driver, ... can't wait to get it tuned right or out of there!
Old Apr 20, 2009 | 02:15 AM
Area47's Avatar
Rent me! per hour
my dyno curves run flat after 7400 and hold that power in variance of .3-.5 whp to 8k when i slam into the rev limiter. it is a characteristic of the blower itself. you do not need the ls4 tb to get the power you want.
Old Apr 20, 2009 | 10:57 AM
ArielAtom's Avatar
Thanks Area! You have confirmed my thinking.
The Supertrapps need to come off or I need to add a bunch more. The other Atom that uses one use a 5" dia version and I use two 4" dia ones. He uses 23 - 5" discs. This means, .... 2x3.14159x2.5x23=361.3" of total disc circumference for the 23. 361.3/(2x3.14159x2)=28.75 discs for me to achieve the same circumference. Basically to achieve the same flow, I need to add 9 discs, however, I had 20% more air flow at 6000 rpm than the other Atom that dyno'd the same day. This means without anymore gain from the Harrop (which keeps going to 7400 rpm) I need a total of 34.5 discs. I am thinking to dyno with an open exhaust and then with 20 discs per side. I am thinking that this is going to be too loud for my tastes
We will see! Thanks for the information
Old Apr 20, 2009 | 11:11 AM
I went the supertrapp route its crap. Sorry. I dyno'd the plates its awful...you gotta find a different way add plates it makes it worse and worse....
Old Apr 20, 2009 | 11:54 AM
ArielAtom's Avatar
Exhaust on these things is a real pain. No room! I currently have two 2.5" V-band flanges pointing straight back. I am first going to try to maintain this system, just from a cost stand point, before scrapping the entire mess.
Old Apr 20, 2009 | 01:25 PM
send me picktars. Can you mount a muffler transversely?
Old Apr 20, 2009 | 01:29 PM
BLAZIN07SS's Avatar
I'm too JDM for you
simple question but has the MAF been rescaled? it could just be maxing out airflow at that rpm
Old Apr 20, 2009 | 01:41 PM
ArielAtom's Avatar
I am here at the office and I left the Atom at home, because, I got really sunburned yesterday. It is basically a really fast tanning bed ...
These are in my pictures:
I will ask the tuner, very good question!
Old Apr 20, 2009 | 01:42 PM
how much was this thing stock?!
Old Apr 20, 2009 | 01:47 PM
SS33's Avatar
<3<3<3
