Flat spot with TVS
Flat spot with TVS
I just dyno'd my car on Tuesday the 14th. I made 315 whp, but, I had a major change in slope at 6000 rpm. The hp to rpm rose steadily until 6000 where it broke sharply and continued to rise slowly from there. Is this a typical TVS trait or is this something more specific to my car?
My Atom uses a straight through 3" exhaust that terminates to Supertrapps. The Supertrapps had 10 wafers a piece on them. After the dyno several fingers pointed to the Supertrapps, unfortunately to late for that session. Other than the exhaust, I think that all other items are very similar to what you guys are using in your Cobalt's. 2.0L LSJ, LS4 TB, 60 lb injectors, return style fueling, valve springs, K&N cone filter with about 18" straight pipe to LS4
If this a typical trait, I will quit wasting time to find the anomaly and go straight into the head and cams using tried and true better breathing techniques.
Specifics as to what I am doing are in the thread "Dyno for a Harrop in an Ariel ", response 86 refers to the dyno https://www.cobaltss.net/forums/show...=157228&page=5
#1. Supertrapps are deadly take them off and attenuate noise differently.
#2 forget the LS4 tb,
#3 fix the exhaust ports in the head
#4 make sure you have the right injectors and PM area47 to tune
#5 q.e.d. Fixed
#2 My tuner will be over on Tuesday to fix my drive ability issues, but, I am about ready to take it and drive over it many, many times
#3 I am going to do a fully ported head and just switch them at some point
#4 I have 60 ib injectors and was unaware that Area did mail order tunes
#5 Maybe I am being dense, but, I don't know what you mean here.
Thanks
Yes, we are using the LSJ computer. I am not the tuner, so, I will ask on your other three questions, I can answer that boost remains consistent at 22 lb and that nothing radical is happening with timing
#1 My first experience with Supertrapps on anything that moves a lot of air. I had a PM from someone that track races an Atom and he stated that he is running at least 23 not 10. If I take them completely off, the car is just to loud. Do you know of another attenuation option?
Thanks
Thanks
'Q.E.D.'= Quad Erat Demostratum. : "That which is demonstrated"....goes at the end of every succesful solved equation...
s**t. cant spell it any other way. And the power it adds ? not worth pouring milk on that cereal....
Last edited by qwikredline; Apr 19, 2009 at 08:42 PM. Reason: Automerged Doublepost
80 mm
Good information .... Thank you!
Ok for the head just port the exhaust, for noise attenuation I recommend a cat, the longest resonator/diameter you can package and a Corsa Daytona Prototype muffler and a turn down at the tail pipe....the injectors are okay and I now (after some work here) can say I consider area47 the most awesome of tuners, and for $ he will (maybe) work for you
I haven't given up on it yet, but, just imagine it in a 1350+/- lb car! The little hiccups slam you in the seat and make you look really talented as a driver, ... can't wait to get it tuned right or out of there!
my dyno curves run flat after 7400 and hold that power in variance of .3-.5 whp to 8k when i slam into the rev limiter. it is a characteristic of the blower itself. you do not need the ls4 tb to get the power you want.
The Supertrapps need to come off or I need to add a bunch more. The other Atom that uses one use a 5" dia version and I use two 4" dia ones. He uses 23 - 5" discs. This means, .... 2x3.14159x2.5x23=361.3" of total disc circumference for the 23. 361.3/(2x3.14159x2)=28.75 discs for me to achieve the same circumference. Basically to achieve the same flow, I need to add 9 discs, however, I had 20% more air flow at 6000 rpm than the other Atom that dyno'd the same day. This means without anymore gain from the Harrop (which keeps going to 7400 rpm) I need a total of 34.5 discs. I am thinking to dyno with an open exhaust and then with 20 discs per side. I am thinking that this is going to be too loud for my tastes
We will see! Thanks for the information
Thanks Area! You have confirmed my thinking.
Exhaust on these things is a real pain. No room! I currently have two 2.5" V-band flanges pointing straight back. I am first going to try to maintain this system, just from a cost stand point, before scrapping the entire mess.
send me picktars. Can you mount a muffler transversely?
I am here at the office and I left the Atom at home, because, I got really sunburned yesterday. It is basically a really fast tanning bed ...
These are in my pictures:
I will ask the tuner, very good question!
