gauge pillar fuses?
Old May 12, 2009 | 02:16 PM
thatotherguy's Avatar
gauge pillar fuses?
Where is the boost gauge fuse located? I pretty sure i blew the fuse!?
awesome yall, thanks for the HELP!!
Last edited by thatotherguy; May 12, 2009 at 02:19 PM. Reason: Automerged Doublepost
Old May 12, 2009 | 02:22 PM
ShortStack's Avatar
Well give it more than 5 minutes.
And actually... if you wanna be like that.. this isnt even in the right section..
This should be posted under electronics.. maybe someone will be able to help you better there.. since this is the performance section.
Last edited by ShortStack; May 12, 2009 at 02:22 PM. Reason: Automerged Doublepost
Old May 12, 2009 | 02:27 PM
Its been more than five minutes. but inside the car i cant find the number 1 fuse that says fuse plr. its like the diagram is different
Old May 12, 2009 | 02:28 PM
Brian MP5T's Avatar
Why the **** are you making many threads about the same thing... You think that will get a reply faster?
https://www.cobaltss.net/forums/problems-service-maintenance-69/boost-gauge-pillar-fuses-170828/
Old May 12, 2009 | 02:29 PM
no im trying to install my wideband and i cant because i have no power to any of my gauges and i need help quick
Old May 12, 2009 | 02:31 PM
ShortStack's Avatar
No it wasnt.. the original post is at 2:16... your double post occured at 2:19.. which is 3 min...
I rounded it off for you... My number was higher anyway.
Old May 12, 2009 | 02:36 PM
ok...
ShortStack's Avatar
Anyway.. it is in the same place that he described in the other thread..
Give me a few minutes ill run out to my car.
Old May 12, 2009 | 02:37 PM
Ok thanks.. i just cant find which one it is. the diagram doesnt look the same
Old May 12, 2009 | 02:55 PM
ShortStack's Avatar
^^ Im not gonna be able to take a break at work.. i can check after 6.
Old May 12, 2009 | 02:57 PM
ok well just let me know... im gonna go out there and try to figure out which one it is. but thanks man
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
Sep 26, 2015 06:44 PM
