Possible Max for High Pressure Fuel Pump?
I've been thinking about this ever since the LNF CEL codes were posted and I looked through them...
It looks like there is a code that pops up when you go over 2500psi. Being that the engineers designed it to throw a code when that happens, I'm wondering if that's at or near the limit or over the efficiency point for the high pressure fuel pump.
Does anybody know of any definate limitations of the high pressure fuel pump?
I'm thinking that looking into some of these codes provide clues into the inner workings of the ECU (and LNF in general) and therefore give up some tuning hints. This may be a heads-up that even with fuel tables unlocked, we may still be up against a horsepower wall caused by the fuel pump and should therefore look into a solution to meet this possible need for when the tables are finally broken.
Input? Technical info? Discuss...
good point.... im pretty bad at tuning... have no idea how to do it... but you do have a point... may be tuners can save time by just looking into the graph and saying " ok we cant go over this amount of psi"...
Ive seen higher than that stock at WOT near redline. 2400 is about the highest Ive seen, but I wasn't datalogging so I don't know if it went higher - not a good idea to be staring at gages when you are going WOT..
If you're doing 2400psi now and the max from an ECU error standpoint is 2500psi, then that's not much room to work with. There may have to be some fuel pump swapping or ECU reprogramming. Hopefully the pump is just underrated.
Fuel pump efficiency range is not a factor in tuning; fuel pump ceiling numbers are. (excluding boost-a-pump hackjobbery which we will leave out of this discussion). In short a modern car fuel pump will either supply enough fuel or it will not, you will not make any more horsepower being at 50% vs 99.9% pump capacity. Naturally hitting the actual pump limits will have consequences
There are 2 pumps on the LNF Cobalt, a traditional electric pump in the back and a second high pressure pump which is driven off the camshaft. Max stock pressure is 2250psi and it will rise with rpm (not necessarily linearly). The high pressure pump on Direct Injected engines like the LNF is there to atomize fuel ; as long as the fuel is properly atomized, more pressure won't really get you anything. More power and higher cylinder pressures will also not impact Direct Injection pressure requirements because it still functions like a traditional four-stroke engine with the fuel being injected opposite the combustion stroke.
Having said that, I wouldn't hold my breath for any aftermarket higher flow injectors anytime soon. There is a fairly small number of DI cars, none of which have heavy aftermarket support. There is also a huge liability in making injectors to safety handle 2250 psi vs 100psi as well as more heat.
Cliffs: Not an issue.
-Mike
-Mike
the reason for the 2500 is because more fuel pressure will cause issues at stock setup .. vince at trifecta is working on some fuel pressure solutions that are looking pretty good so far as well as some map changes so you can do 26psi on stock setup
-Mike
-Mike
I'm not sure about a max of 2250 though considering IsItFast just stated he's had his up to 2400 already.
I agree that the chances are slim as of now for aftermarket DI products. Hopefully as GM/others put out more engines with DI, the spotlight may shift a bit. I wonder if when we get the fuel tables unlocked if we're going to find the concrete max of the pump. I feel that's going to be a very important factor in performance as we move more to the Stage Kits and larger turbo setups.
That would be pretty handy when coupled with the newer 3bar TMAPs.
Thanks for the info.
with the 3 bar maps he could accurately control everything above 24 psi very easily and make the fuel pressure much easier as well .. if he can work that out you'll be seeing a CIA/ trifecta stg kit coming out
hehe he's working on it guys.. right now he's hitting 28 psi on his hhr ss lol it falls off to like 26 at redline more then likelye because it's running out of steam lol it's good stuff so far.. he thinks he sees some things to easily work with the fuel table
Baldturbofreak was saying that the k04 taps out after about 36lbs/min. With the fueling window being an issue and the turbo not being able to flow sufficient air when you're reaching very high RPM, I'm thinking most improvements will be in the mid-range. Up high you're probably looking at falling off pretty quickly, like is what is happening to most everybody that's tuning it now it seems.
I know it's a long shot, but if Vince can pull something off on offering a 3bar sensor + fuel map something-or-other before the Stage Kit is out, I may go with him instead. ...or is it more of a GM Stage Kit addition?
So can he scale a 06 2.2 cobalt using the 2bar sensor from zzp? Everytime I get a tune from him the low end is lean and the high is ok:
3000-4500 I get 12.5a/f
4500+ I get a 11.9-12.1
So hopefully this Sunday we can tune the car over good, I'm running 1 point to lean now, 13+@wot not good LOL
Looks like Vince's secret is out... https://www.cobaltss.net/forums/show...59#post3990459
