Dyno Results Dyno pictures, videos and dyno results.
ABS on dyno?
Old Jun 16, 2009 | 07:48 AM
Snakes709's Avatar
ABS on dyno?
Wasnt sure if this was the correct spot for this post but if it isnt, mods you can move it. Anyways...
When i first dynoed my car when i dyno tuned my stage 2 i was getting really good numbers. Then went i dynoed for meth and then again after that at car shows i hit low numbers. 20-30whp lower. Thought it was a coolant leak cuz i had a small leak cuz one of the hoses of the aftermarket h/e was coming loose but i fixed it and same issue. The last few times i dyno'ed i notice my ABS light was on. Could that cause the dyno readings to be false. ie...would it cause the wheels not to spin 100% since its trying to do its job?
Old Jun 16, 2009 | 07:51 AM
ls1fbody's Avatar
Haz l33t wheelz.
its slightly possible, but it's more likely that its unrelated and you have a connector loose somewhere, probably the wheel speed sensor.
Old Jun 16, 2009 | 08:26 AM
Wickedlsj's Avatar
Completely normal. ABS control module notices that the front wheels are spinning really fast while the back wheels are not moving at all. It sets a code but shouldn't affect your results. Typically though, you want to disable traction control if you have it to ensure that there is no problem.
Old Jun 16, 2009 | 08:35 PM
Snakes709's Avatar
ok cool, i think i found the issue, small coolant leak and a big leak in my meth kit, fixed both and car feels better.
Old Jun 18, 2009 | 11:52 AM
2K5SS/SC?'s Avatar
Pull the ebrake when setting the car up on the dyno. That should shut off the ABS light if I remember correctly.
Meadowvalien
Aug 17, 2017 06:32 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 27, 2015 08:53 PM
jthwjde
Sep 7, 2015 09:24 AM
