ZZP LNF Update- New Track Times
Old Jul 4, 2009 | 03:46 AM
Matt M's Avatar
We took the 08 SS/T to the track Friday night for some test/tune. The previous best time on this car was a 12.91 at 113.75. The only major change since then was a ZZP IC upgrade, and we started to bump the boost up a little. The track was busy tonight, and our race night started poorly. On the first pass, one of the clamps came off the charge tube right after the launch. We fixed that, but a different coupler came loose on the next pass. This time, it happened late enough in the pass that it didn't affect the ET much. This pass was a 12.841 @ 114.07, but should have had a bit more mph. For the next pass, Ryan got too aggressive off the line and spun bad. I think it was a 13.1 or something close to that. At this time, we decided to bolt on the slicks. The first pass on slicks was a 12.56 @ 114 with a slow 2.1 sixty foot. This was without any tirespin, so it became obvious that we need to turn up the 1st gear desired air loads and also raise the park/neutral rev limiter to get more RPM at the line. On the next pass, Ryan stuck the launch, but had trouble getting second gear. (The shifter cables are not getting along with us very well in this car.) On this run, the sixty foot was a very nice 1.74! With a 114 trap, this would put us close to 11s. Unfortunately, it didn't work out that way. With the staging lanes closing, Ryan hotlapped and put down a nice burnout, but came off the line a little slow before the car came to life and put down a 1.82 sixty foot. He made a very conservative 1-2 shift and kept his foot planted on the 2-3. We knew this was going to be a nice run and the ET board confirmed it. 12.178 @ 114.18!
All in all, we are pleased with the progress with this car. We have a little ways to go to hit our 11 second stock turbo goal, but we are confident that we can get there.
Old Jul 4, 2009 | 06:11 AM
2K5SS/SC?'s Avatar
Congratulations on the good times! You are definitely going to have to post the slip though as the haters will want proof! What size tires and slicks are you using? Any pics?
Old Jul 4, 2009 | 10:09 AM
Maxim_X's Avatar
It's crazy how hard your 60'ing that car. I have trouble maintaining 2.1's.
Old Jul 4, 2009 | 10:14 AM
dunit121's Avatar
very nice
Old Jul 4, 2009 | 10:34 AM
ecotecturbo's Avatar
Awesome times guys. Very impressive!
Old Jul 4, 2009 | 10:40 AM
rockSTAR_SS's Avatar
No video's this go-around?
Old Jul 4, 2009 | 10:43 AM
orbalt08's Avatar
Awesome times. I bet you guys had a blast
Old Jul 4, 2009 | 10:45 AM
stryder's Avatar
I love this little car!! LOL
Old Jul 4, 2009 | 11:36 AM
damien's Avatar
You ******* are coming off that line hard.
Old Jul 4, 2009 | 11:42 AM
ralliartist's Avatar
damn, stock suspension? What size slicks are you using?
very impressive ZZP!
Old Jul 4, 2009 | 11:47 AM
MarqueDo7BabyBalt's Avatar
holy ****..def. post timeslips for the haters and if u have vids or pix..plz post cuz i want to see haha...nice **** tho..
Old Jul 4, 2009 | 12:31 PM
rollingboostedss's Avatar
very good time
Old Jul 4, 2009 | 12:41 PM
Matt M's Avatar
I don't have all of the timeslips, but here is the timeslip for the best pass-
We have some video, but the processor is on my computer at the shop. I'll get over there and transfer it some time this weekend and get some videos posted.
Yes, it's always fun getting out to the race track. It's even more fun when we can put down some nice times.
Stock suspension with the rear springs blocked. 26x10" Mickey Thompson slicks.
Old Jul 4, 2009 | 12:46 PM
cmiller8006's Avatar
Stock suspension with the rear springs blocked. 26x10" Mickey Thompson slicks.[/QUOTE]
So you guys swapped the brembos for a small brake kit?
Old Jul 4, 2009 | 12:47 PM
mkriebs's Avatar
IMPRESSIVE! I knew this car has 11's in her on the stock turbo. Just out of curiosity, what are you setting the P?N rev limit at?
Old Jul 4, 2009 | 12:54 PM
Matt M's Avatar
Yes, we are running LSJ brakes.
Originally Posted by mkriebs
impressive! I knew this car has 11's in her on the stock turbo. Just out of curiosity, what are you setting the p?n rev limit at?
6000
2K5SS/SC?'s Avatar
So you guys swapped the brembos for a small brake kit?[/QUOTE]
I second that notion! What size rim?
Old Jul 4, 2009 | 01:05 PM
[QUOTE=Matt M;4072364]Yes, we are running LSJ brakes.
Are you running stock axles as well, and did you upgrade the clutch?
Old Jul 4, 2009 | 01:06 PM
mkriebs's Avatar
Originally Posted by Matt M
6000
HOLY ****! I was running about 4 when I broke my CV joint. Are you on stock axles still? I am in the process of developing some for DSS, so I know you aren't on DSS axles, unless you swapped out the hub for an SC hub...
Old Jul 4, 2009 | 01:12 PM
Matt M's Avatar
[QUOTE=cmiller8006;4072408]
Yes, stock axles. They are very strong on the LNF.
Yes, we are running a ZZP clutch.
Old Jul 4, 2009 | 01:22 PM
mkriebs's Avatar
[QUOTE=Matt M;4072432]
I am convinced I got a a lemon axle. Cuz, 4k on street tires should not be breaking them, when i am only tuned.
Old Jul 4, 2009 | 01:25 PM
drew1991sf's Avatar
very nice job matt. wat stg zzp clutch are u running? is it stock flywheel?
Old Jul 4, 2009 | 01:34 PM
rico's Avatar
bad ass run
Old Jul 4, 2009 | 01:49 PM
so you are launching off the p/n rev limit? does that cut spark or just fuel?
I know on the LSJ it only cuts fuel.
Old Jul 4, 2009 | 01:51 PM
mkriebs's Avatar
Seems to me it cuts both, because I am running perfectly stoich when I am staging when i run it off the p/n limiter.
