Clear Image Automotive Clear Image Automotive is a Supporting Vendor
Reps: Clear Image (Beth), ClearImageAuto Dan, TCASON
CIA performance CP
Old Jul 24, 2009 | 08:44 AM
CudaJoe's Avatar
CIA performance CP
Dan,
I was just curious about the performance charge piping you sell, (the one with the shorter travel distance for charged air)...
You said it is one solid piece, but I was wondering if it runs directly over the oil filter cap?
If thats the case then it might be a big pain in the butt to change the oil in the car.
or does the charge pipe run across the engine in a way that you can still easily get to the oil filter cap?
Old Jul 24, 2009 | 09:25 AM
northvibe's Avatar
Originally Posted by CudaJoe
Dan,
it doesnt look like it covers the oil but on of the spark plugs...so it would be interesting to hear if its easy to get to that plug.
Old Jul 24, 2009 | 09:30 AM
CudaJoe's Avatar
how can you tell? lol, I cant even see the oil filter cap!
Im thinking they should make the hot side two pieces simply so its easier to access the engine.
Old Jul 24, 2009 | 09:51 AM
northvibe's Avatar
scroll over yes it clears the oil cap just fine. Its the 2nd plug over you should be worried about.
DAmn it you meant FILTER!!! aahhhh hahaha sorry dude. Ummm idk then.
I looked at the other pic they have and it looks like it covers that little hole you get to put the socket through. I'm 90% sure you'd have to remove the pipe to do a oil change.
http://www.clearimageautomotive.com/...s/DSC00634.JPG
Old Jul 24, 2009 | 10:06 AM
CudaJoe's Avatar
ugh that really sucks, rallycobalt06 had a 1.25 inch hexigonal rachet and it fit like a glove, looks like stockwise you can simply use that plus a 10" extension to get it and the ratchet is a snug fit against the hot side stock charge pipe.
Like I said, I think they need to make the hot side into two sections, at least make it an option. That way it can be rotated out of the way.
Old Jul 24, 2009 | 10:07 AM
northvibe's Avatar
the current one almost looks like it can be rotated... just undo the back clamps and move it to the left (passenger side).
CudaJoe's Avatar
actually, I just looked at the pic you posted. It might have enough room after all?
Old Jul 24, 2009 | 10:16 AM
northvibe's Avatar
the hole to drop the extension is just right of the intake manifold. I think that pipe covers it. BUT I think if you undid the coupling on the turbo to the CP you could move the pipe over a inch or couple and get it to work.
Old Jul 24, 2009 | 10:19 AM
Stamina's Avatar
I've got the CIA performance pipes on my car. Let me know what pics you're wanting specifically and I'll take/post them up over my lunch break or after work.
I didn't take note of position up top. You may need to loosen one clamp to change the oil filter. Honestly though, the clamp up by the turbo (pipe side of it) is one of the easiest IMO to get to and insure it's tightened down. So don't stress too much about that positioning.
The whole set consists of three pipes. Turbo-to-radiator area basically, radiator area to the IC, then the coldside between the IC and throttle body. The position/angle of the one clamp in the radiator area is such that you can rotate the top pipe left and right across the engine if need be.
Old Jul 24, 2009 | 10:24 AM
northvibe's Avatar
sweet, yeah post pics of looking top down on the engine, specifically where the oil filter is. And on top of the engine for me, I want to see where the pipe covers the plugs.
Thanks!
Old Jul 24, 2009 | 10:34 AM
reign1's Avatar
ill show u a picture. u can decide
yeah it goes right over. lol.
i pay 10 bucks for labor on my oil change. worth every penny for no hassle...
Old Jul 24, 2009 | 10:36 AM
Mazdaboi318's Avatar
who does it for you?
Old Jul 24, 2009 | 10:37 AM
reign1's Avatar
Superautobacs (not called superautotoyz)
Old Jul 24, 2009 | 10:40 AM
northvibe's Avatar
yup cudajoe that is directly over the oil filter.
Old Jul 24, 2009 | 10:55 AM
CudaJoe's Avatar
awww. lol. I guess if I asked Dan, when ever I plan on getting that pipe, I'll get him to cut the pipe just after the first bend on the 5inches of straight segment there.
Old Jul 24, 2009 | 10:59 AM
northvibe's Avatar
like the others said too, I dont think thats necessary. I think if you just undo the coupler on the turbo you can easily turn the whole charge pipe to the side and have room. But you could cut it too I suppose...
Old Jul 24, 2009 | 11:13 AM
Stamina's Avatar
Yeah, like I said, just loosen the top clamp and rotate. It's uber easy.
I was worried about the oil filter/CP overlap too before I ordered them, but it's turned out to be a non-issue with as easy as it is to reposition.
Old Jul 24, 2009 | 11:18 AM
northvibe's Avatar
do you put something over the turbo so nothing falls in?
Old Jul 24, 2009 | 11:24 AM
Stamina's Avatar
I didn't since there wasn't anything around that could fall in at the time. I'd probably recommend it looking back though, especially if you're going to leave it for a while. Bugs are known for crawling up in things when you leave.
Old Jul 24, 2009 | 11:47 AM
CudaJoe's Avatar
I'd use a fluffy little kitten. there not strong enough to pull them selves out of the turbo and their fur can clean the inside of the turbo.
Old Jul 24, 2009 | 11:54 AM
julius41282's Avatar
So if you get this CP, then you basically should start changing your oil yourself? Cuz I know the dealership is gonna be like WTF?? How am I supposed to do this!
Old Jul 24, 2009 | 12:02 PM
northvibe's Avatar
I'd say most people change their own oil. I know I do all my own work unless its warranty. I dont trust others....
Old Jul 24, 2009 | 12:08 PM
I got a free oil change so I couldn't pass it up! Just saying that they might even turn you away b/c they may not want to touch anything aftermarket.
Old Jul 24, 2009 | 02:03 PM
northvibe's Avatar
maybe but charge piping is more of appearance/air flow they probably wont question it. A intake though...yes they would question that.
Old Jul 24, 2009 | 02:48 PM
To my surprise...the dealership said nothing about my intake or CP...I guess they didn't care.
