Factory Brake Proportioning Valve
Old Jul 25, 2009 | 01:33 AM
Mr. Flipflops's Avatar
I just recieved a factory non-abs proportioning valve/block and i am trying to desifer what port goes to what line (RF, LF, RR, LR). The reason i need to know this is because i am using it on my 99' Buick Regal due to deleting my ABS and saving some weight. Any help with this would be great so that i make sure that the fronts and rear are on correctly! Thanks
Here is a picture of the piece that i am talking about:
Old Jul 26, 2009 | 01:24 AM
Nobody has a non-ABS car that can trace a few lines and tell me what port goes to what wheel?
Old Jul 26, 2009 | 11:22 AM
LTBALTBMX's Avatar
wrong car forum?
Old Jul 26, 2009 | 11:26 AM
2FST4U's Avatar
maybe google. or try your local dealership and see if they can print you off a copy of the Mitchell write up
Old Jul 26, 2009 | 01:55 PM
qwikredline's Avatar
wont work very well on yr regal
Old Jul 28, 2009 | 09:08 PM
Maven's Avatar
I am gonna highly recommend you DO NOT USE THAT ON A REGAL
I would recommend using some quality aftermarket adjustable proportioning valves for your project.
But since youre apparently doing it this way this is how it gets plumbed, again I STRONGLY STATE THIS IS A BAD IDEA
Note that this is diagonally split, so one side feeds the LF and RR, and the other side feeds the RF and LR, this will affect your bleeding procedure.
The primary feed from the master cylinder would usually go to the LF/RR pairing
If it were from a Solstice, it would be slightly less bad, but still far from ideal.
Old Nov 2, 2009 | 11:36 PM
Any reason why? It has worked flawlessly since the install, 2 months ago.
Old Nov 3, 2009 | 11:54 AM
Maven's Avatar
It will always work fine until it reaches the limit. Its designed for a car with lower fluid volume and smaller calipers and wheel cylinders, thats why its a bad idea. Its not the proper pressure balance.
I never said it wouldnt work, I said I think its a bad idea and i wouldnt recommend it.
Theres a huge difference between something working and something correct.
I could tell you I use water or CocaCola in my brakes instead of DOT4......You could say its a bad idea, and advise against, I would tell you it works fine and I'd be right. But that doesnt mean that its safe or correct.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
biniecki
Oct 25, 2015 02:23 PM
Trav3480
Sep 28, 2015 02:46 PM
