about to install dual pass/option B/heat exchanger
Old Oct 1, 2009 | 10:10 PM
JAYNO20's Avatar
I got all the stuff from OTTP, I could not find a diagram that included the option B tank instead of the original fill cap thing... Just wondering what all I need to know to do this myself and what problems are usual to run into.
Old Oct 4, 2009 | 05:10 AM
JAYNO20's Avatar
anyone?
Old Oct 9, 2009 | 02:06 AM
JAYNO20's Avatar
Old Nov 5, 2009 | 09:37 PM
JAYNO20's Avatar
OK guys I am probably just going to be installing the Option B and the heat exchanger... can any of you guys who already did this offer up any info that might help a first timer out? I am going to be doing it this weekend so any help is greatly appreciated.
Old Nov 6, 2009 | 03:50 AM
JAYNO20's Avatar
So no one has done this eh?
Old Nov 6, 2009 | 05:14 PM
Red05SS/SC's Avatar
Your better off running a "stu" mod type resevoir than an option b for the fact that the fluid flows through it instead of just expanding the system to hold more fluid. With that said if you know which way the coolant flows then just run everything how you want to.
Old Nov 7, 2009 | 03:51 PM
JAYNO20's Avatar
I have no clue how anything flows or how anything is hooked up, that's where I was hoping for some input on the whole ordeal.
Old Nov 8, 2009 | 12:18 PM
Red05SS/SC's Avatar
there is a diagram on here somewhere and I think it may be on OTT's website for flow. The way you are talking you might want to try and find somebody local to give you a hand who has done it before.
Old Nov 8, 2009 | 05:13 PM
Tennpenn83's Avatar
do a search. i have posted a diagram on this 100+ times now
Old Nov 8, 2009 | 05:50 PM
mrbelvedere's Avatar
put a t fittimg in place of your old fill spout and hool that into the option b tank
Old Nov 13, 2009 | 06:12 PM
JAYNO20's Avatar
does anyone know if I will have any fitment issues using the lower grille insert with the aftermarket heat exchanger? It looks to be a pretty tight fit..
Old Nov 13, 2009 | 06:20 PM
ItalianJoe1's Avatar
You shouldn't have issues, the grille insert doesn't really hang back through the bumper...
As far as install, it's a long process, and has been explained on here many times. I've helped a lot of people who bought my dual-pass plates through it, if you have any specific questions, i'll be glad to help. If you are looking for general instructions, there are several threads on installing the dual-pass that will explain it.
Old Nov 13, 2009 | 06:23 PM
JAYNO20's Avatar
I am probably going to be skipping the dual pass end plate, right now I am just looking to do the option B setup with an OTTP heat exchanger...
Old Nov 13, 2009 | 06:27 PM
Option B is just a larger expansion tank, kinda pointless without the endplate...
Just do your H/E now, and do the endplate with option B later. You'll be in the area anyway and running hoses.
Old Nov 13, 2009 | 06:36 PM
JAYNO20's Avatar
I am saying I probably won't ever do the dual pass end plate....
Old Nov 13, 2009 | 08:32 PM
Red05SS/SC's Avatar
It's not hard to do. You could have the manifold off and back on in 2 hours or less and then its just a matter of running hoses. I wouldn't not put it on just because you don't know what your doing. Either just go for or find somebody who has done it before and see if they can help you and then you can learn at the same time.
Old Nov 14, 2009 | 05:59 PM
JAYNO20's Avatar
is there any pictures on where the intercooler pump is located and how to run the hoses?
Old Nov 14, 2009 | 10:29 PM
Red05SS/SC's Avatar
the intercooler pump is directly under the manifold. If you get under the car you can see it much better.
Old Nov 15, 2009 | 04:20 AM
JAYNO20's Avatar
on the OTTP heat exchanger which one is the inlet and which is the outlet?
Old Nov 16, 2009 | 01:18 AM
JAYNO20's Avatar
Old Nov 21, 2009 | 04:17 AM
JAYNO20's Avatar
OK just found it after some searching... top is inlet bottom is outlet...
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
n20saturn
Sep 30, 2015 12:26 AM
Sep 27, 2015 08:53 PM
