Can a turbo
Old Oct 2, 2009 | 12:46 AM
LsBro07's Avatar
Can a turbo
running no more than 6psi, on everything stock blow your engine ?
Old Oct 2, 2009 | 12:47 AM
krishansheanh's Avatar
at 6 psi, highly doubt it.
Old Oct 2, 2009 | 12:49 AM
LsBro07's Avatar
sweeeet=D thank you
Old Oct 2, 2009 | 12:50 AM
if your only gonna run 6 pounds why not throw an m62 on there? assuming your car. instant boost and probably more power
Old Oct 3, 2009 | 03:27 AM
LsBro07's Avatar
idk what a m62 is,
still havent learned all that..
explain ?
Old Oct 3, 2009 | 03:39 AM
Wolf117's Avatar
m62 is the stock supercharger off the ss/sc
Old Oct 3, 2009 | 03:45 AM
wrathofgod's Avatar
quit whinning and go turbooo
lol not trying to fight i just loove turboss
Old Oct 3, 2009 | 03:55 AM
you wanna deal with boost lag for 6 pounds of boost?
look at some m62 bolt on LS's. they pull out 260whp. perfectly safe
Old Oct 13, 2009 | 07:26 PM
Turbo06Sedan's Avatar
just because they pull out 260whp doesnt mean its perfectly safe.
Hell, i've been at the 300whp mark for awhile now, and ***** starting to go wrong....so its not "perfectly safe", but it held up good for months.
To the OP, yes. 6psi can infact blow a motor. Depending on how big the turbo is. Ya, it might take a few grand to spool, then boom.
As for the other posters, and to the OP. a GT28RS on a 2.4 provides instant boost.
Regardless, good luck. But you can push a PROPERLY sized turbo to about 8psi without having to worry about blowing the motor, as most motors are pressure tested during manufacturing to about 10psi.
Old Oct 16, 2009 | 07:10 PM
LTBALTBMX's Avatar
260 whp, not on stock internals...
Old Oct 16, 2009 | 10:11 PM
b_faulk75's Avatar
Well i've been running 9 psi on a bone stock 2.2l engine with a good size turbo and i haven't blew up YET, i doubt i go much more on stock internals but now my clutch is slipping so that's obviously the first week spot... I plan to find out at some point how far i can go...
Old Oct 16, 2009 | 10:55 PM
Jrhdpaintball's Avatar
ur car is sexy in person faulk, still my favorite car during the car show
Old Oct 29, 2009 | 01:31 PM
jrocstar's Avatar
if you blow up your car on 6psi and it is not some ridiculous sizes turbo you are doing something wrong. hell even if it is some ridiculous sized turbo. at 6psi you wont even need an intercooler! if yuor af ratio is good and ignition timing is good then it will be fine. I ran 20 psi on a stock car that had all cast components before.
Old Oct 29, 2009 | 01:33 PM
cobaltguy889's Avatar
6psi on what size turbo. There is a difference between 6psi on a t25 and a t3/t4
Old Oct 29, 2009 | 01:43 PM
06blackbalt's Avatar
go with the M62 you get instant power
Old Oct 29, 2009 | 01:54 PM
lwpmoon's Avatar
Like everyone is saying, it depends on what turbo you will run. I recommand the gt2860rs. That's what I have been running on 10 psi for ~6 months and 20 passes at the track and zero down time.
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
