Sparks Plugs!!!
Hey guys i need a new set of spark plugs was wonderin which ones to get.. i hear many different types but the 2 i hear the most that we should use are
NGK Spark Plugs Iridium
NGK Copper Tipped spark plugs
now im stock SS/SC with only 1 mod being a K&N Typhoon intake.. so which set should i get???
I been told by many many many different people who run high boost application cars to stay FAR FAR FAR away from plugs that say Iridium, and Copper Tipped spark plugs apparently they are no good.
but Damian the 2 step colder ones they are not Iridium are they?
i believe the 2 step are. Thats what i ran in my car and never had a issue....had to keep swaping them because someone wouldnt fess up that they fucked up on the tune and blamed the plugs. And then of course the issue with the dealership putting the wrong type in my car when they got changed.
Do they many many many people happen to drive hondas hondas hondas?
If you are stock with only an intake for a mod changing the spark plugs is pointless. You will not get any advantages to changing the plugs and may cause problems. If you really, really want to switch them for something else go with the BKR6EIX (iridium stock heat range).
lol.. ok i'll explain myself again... only mod i have is an intake... other then that ..its stock... plugs have not been changed in 4 years..so i wanna put a new set it.. i'm askin.. what set should i by... NGK Copper tips..right?
The BKR7EIX is only one step colder. Truthfully, you should have gotten the BKR6EIX to stay in the stock heat range.
With your mods there is no reason to go with copper plugs unless you are having problems with spark knock.
agentirons
Oct 16, 2015 02:11 AM
