Painting the Plastic EcoTec Supercharged
Old Nov 6, 2009 | 12:21 AM
RazzKazz's Avatar
Canada Painting the Plastic EcoTec Supercharged
Do i need to sand this .. cause i just tryed to paint it and it ran off it and is there a certin brand of paint i need to do it with???
Old Nov 6, 2009 | 12:35 AM
JAYNO20's Avatar
you are spraying it with primer first right?
Old Nov 6, 2009 | 12:48 AM
RazzKazz's Avatar
lol well ***.. thats what i forgot to do hahaha... is that all i needed to do??
Old Nov 6, 2009 | 01:08 AM
Snakes709's Avatar
what colour is your car. I have the polished steel spark plug cover that says "Cobalt SS" and fual rail cover that says "Supercharged" in blue lettering that im selling.
Old Nov 6, 2009 | 01:30 AM
RazzKazz's Avatar
oh what else do i gotta do to get the paint to stick the aluminum piece on top of the engine..??
I have a Red SS.. im not sure Blue on red would look so good... how much do u want for them??
Old Nov 6, 2009 | 08:48 AM
pykie's Avatar
you must sand it down, a good start out sand grit is 600grit, then move to 800 grit for a final prep sand, spray ur etching primer on the metal u are painting (if its bare metal you MUST use a etching primer or it wont work) spray 2 coats of primer and with 1000grit then whipe it clean and paint it
Old Nov 6, 2009 | 12:13 PM
RazzKazz's Avatar
is sanding primer good enough???
Old Nov 6, 2009 | 12:36 PM
pykie's Avatar
no, a normal primer such as sandable primer will not work, what happens is it wont stick.
thats why you MUST use a self etching primer
Old Nov 6, 2009 | 12:42 PM
roderick's Avatar
FAIL LOL search google How to paint somthing with spray paint. You MUST sand it , Wash is with water, primer is 3 coats, paint it 5 coats, clear coat 5 coats.
Old Nov 6, 2009 | 12:46 PM
Gestapo007's Avatar
^exactly. etch primer has acid in it and adheres itself to the metal.
not true at all. you must scuff anything you paint for it to stick. wether its a scotch brite, or a high grit sandpaper, you just have to scuff it. Bare metal you need an etching primer, painting over something thats already painted, you need regular primer. Painting over plastic you need adhesion promoter and plastic paint.
dont need 3 coats of primer and 5 of paint and clear, those numbers are based on what? you use as much as you need. usually the paint you use will tell you how much you need. when spray bombing, use enough paint to cover the surface and make it even, then clear with a coat or 2
Old Nov 6, 2009 | 12:53 PM
RazzKazz's Avatar
ok u guys got me so lost right now... uguys have told me 3 different steps.. plus useing 3 different types on stuff.. meh!
Old Nov 6, 2009 | 01:07 PM
pykie's Avatar
What are you painting show a pic of it?
is it metal or plastic.
is it painted before or no.
Old Nov 6, 2009 | 01:16 PM
RazzKazz's Avatar
ok ... this is what im doing...
I'm paint the aluminum cover on top of the engine where plugs are and im painting.. the plastic piece that covers the spark plugs ... is that good enough??
Old Nov 6, 2009 | 01:18 PM
Gestapo007's Avatar
^Pykie is right, so just listen to him. is that badge real metal or just plastic?
Old Nov 6, 2009 | 01:28 PM
RazzKazz's Avatar
the top is aluminum and the other piece is plastic..
Old Nov 6, 2009 | 01:32 PM
pykie's Avatar
Doing the valve cover with high heat paint? or like a base coat clear coat?
i did mine with base coat clear coat.
when i did min i used a wire wheel to clean the valve cover and used a primer, i was dumb and wanted it done and didnt use a self etching primer and now im regreting it.
you sand the cover, prime it with self etching primer with 2 coats, then sand the primer with 1000 grit (stay away from scotch brite pads) then paint your coats of paint, when doing base clear on small items like that i like to use 3 coats of base, and 5 coats clear.
when it comes to paint you cant really **** up, but with clear coat u lay alot down and you have a peice of dirt or something in it you can always wet sand it out...
now when painting with spray bomb i wouldnt bother with a primer sense high heat paint normally says on the can you dont need to ise a primer, just requires a really good clean surface so just sand the surface with 600 grit then 800 grit and sprat the paint.
ther plastic part covering the plugs.. just sand that with 600 grit then 800 grit and lay the paint to her. and u be good.
CobaltSC06's Avatar
you're painting the valve cover and the ecotec supercharged plastic cover? what colors?
Old Nov 6, 2009 | 01:48 PM
RazzKazz's Avatar
thanx for the steps dude.. i did it...worked so far..starting to look good... and im painting its Gm Victory Red.. same as my car...
Old Nov 7, 2009 | 04:13 PM
curriet1's Avatar
fire some pics on here man
Old Nov 9, 2009 | 09:55 AM
Platinum_Injected's Avatar
yes pics!!
Old Nov 9, 2009 | 08:41 PM
RazzKazz's Avatar
Canada
here is an update before i post pics... well the top cover came out pretty good.. it hink pretty good for the first time ever doing this...the plastic piece meh not so good... gunna have to redo it.. some of the paint peeled..when i was taking the tap off .. but it fur sure helps make the engine bay stick out more... i'll post pics after the redo..
Old Nov 10, 2009 | 05:35 PM
pykie's Avatar
did yo use painters tape?
theres 3 different kinds of painter tape that i know of.
1. Blue - most stickiest tape
2. dark green - in the medium range of stickyness
3. light green this is what you would use when taping of fresh paint.
when i did this valve cover i painted it blue then taped off the blue to make the rising sun with light green tape.
and then used the dark green tape to hold everything tightly
when i did this valve cover i painted it silver then painted the silver of to make the rising sun using the dark green tape and it pealed the paint.
But overall when it comes down to paint pealing alot of the time its because of not good enough sand job was done.
Old Nov 10, 2009 | 05:54 PM
RazzKazz's Avatar
dude.. that is the coolest idea and paint job ..iv seen on that... i could sit here and stare at it all day... thanx for the 3 kinds of tap... but ya.. im more amazed witht he rising sun.. soo kickass
Old Nov 10, 2009 | 06:01 PM
pykie's Avatar
lol thanks, did them for 2 of my buddies, they wanted the honda vtec shaved off them so people didnt know they had a d series with v tec... even though the sohc is the most worse one out there lol
i been practicing my air brush skills, and what not, i hope to do my valve cover so that it looks as if its see thru and you can see the cams chilling inside the head.
if i cant figure this out then i dunno what im doing with my valve cover.
Old Nov 10, 2009 | 09:59 PM
Gestapo007's Avatar
very nice pykie. you using rattle can caliper paint for valve covers?
