Launching with DR's
Old Nov 12, 2009 | 02:20 PM
BYT*SS*TURBO's Avatar
Lightbulb Launching with DR's
Ive been tracking the car all summer trying to get into the 12's. My local track is just awful!! While I keep gaining more and more Trap Speed my 1/4 time has stopped improving. I have to leave the line at 2500ish and ease into the throttle, almost like it was a stop light!!
I have a set of SS/NA's for winter and just saw the Import vs Domestic showdown coming up at Atco... So I bought some Mickey Thompson ET Street Radials for the SS/NA's. I have NEVER raced on DR's before, slicks yes! I have some questions to limit the amount of trial and error when I show up next weekend. I really would like to get into the mid 12's, I think my trap speed is high enough to make it possible. Typically run 13.1-13.2's at 114-115mph.
What would be a good RPM to start launching at? Are you doing a quick burnout with the DR's or a long one like they were slicks? 2nd gear burnout?
I have the TTR Solid Motor Mounts but Id like to TRY and not break my stock axles next weekend LOL..
Old Nov 12, 2009 | 02:40 PM
blackbolt89's Avatar
**** import v domestic is next weekend?!?
i was out of a car for the last month and totally forgot about this. i'd love to see how shitty my LS can do. lol.
Old Nov 12, 2009 | 02:47 PM
Yea, 11/22 Atco Raceway.
Old Nov 12, 2009 | 02:51 PM
tREBs's Avatar
They are a softer compound than street tires so a SMALL burnout may not be a bad thing, Maybe a quick spin to heat them up a little bit.
as for launching, your first time down the track should somewhat be your "trial" run, figure out track conditions, hook or not etc...
I would try a 3500rpm launch first, and go from there. IF there is no room for a trial run pass then ask people who have already ran and ask them there thoughts on track conditions and estimate based on what they say...
Good luck!
Old Nov 12, 2009 | 02:54 PM
i love having a weak car. i can launch at WOT and not even get too much wheelspin if any. :P
maybe ill see you there BYT.
im still debating on whether or not i want to waste money to see how slow my car is.
ecotecturbo's Avatar
Did you nls on those 13.1 passes?
Old Nov 12, 2009 | 03:13 PM
Yea on the 2-3 and 3-4 shift.
Old Nov 12, 2009 | 03:19 PM
mongorat427's Avatar
I ran drag radials at 19 psi and left at 5000 rpm with a 1.88 60 ft time. Im having trouble with the 1-2 shift. It dosnt want to go into gear over 6000 rpm even with the new shifter
Old Nov 12, 2009 | 03:27 PM
383_Stroker's Avatar
I had that problem (mine was like you hit a wall when you went to shift at high rpms).. Mine turned out to be be a problem where the seal that goes between the line that comes to the trans and the nipple on the trans had popped off the ridge that holds it. So it would work fine on a slow shift, but when you punched the pedal to make a fast shift, it would leak around the seal and not put engage the clutch.. took me like 3-4 months to find the issue
Old Nov 12, 2009 | 03:43 PM
cmiller8006's Avatar
So what size did you buy?
steddy2112's Avatar
Axles aren't what will break.
Old Nov 12, 2009 | 03:53 PM
ralliartist's Avatar
just be careful. You might see some more wheel hop than normal since you will be trying to launch harder. wheel leads to broken axles or worse, trans. I would have gotten slicks personally.
Old Nov 12, 2009 | 03:56 PM
whyyoumadson?'s Avatar
big second gear burnout. heat them up
turboss09's Avatar
what track is your home track? Do you ever head down to maple grove cause that's my home track and not to far from you
Old Nov 12, 2009 | 03:59 PM
VeNoM0713's Avatar
wow, i have that same problem.. ever since i got my spec 3+ clutch installed my car hates the 1-2 shift.. its like i have to force it to go in and sometimes that doesnt even work.. its only the 1-2 shift also and its only at the higher rpms like you were saying. how did you fix it?
Old Nov 12, 2009 | 04:04 PM
D4u2s0t's Avatar
be careful, there has been many a broken cobalt as a result of atco.
Old Nov 12, 2009 | 04:05 PM
steddy2112's Avatar
There's been a lot of broken **** period because of Atco.
Talk about HOOK.
Better have your **** right or you will break.
Old Nov 12, 2009 | 04:18 PM
D4u2s0t's Avatar
Talk about HOOK.
when was the cobalt meet where like half of them never got past the 60' lol
Old Nov 12, 2009 | 04:27 PM
steddy2112's Avatar
His mount situation will not help him either.
Old Nov 12, 2009 | 05:10 PM
SSReepur's Avatar
I would really like to learn how to launch with drag radials also, and what psi to drop them to
Old Nov 12, 2009 | 05:18 PM
beast10007's Avatar
This is true. Also try launching around 5,000rpm but ride it out. DR's are great but they still spin I have some g-force DR's that I ran on my eclispe. but on 17" you should get around 1.8 60ft
I ran 20psi but I never tryed any others
Old Nov 12, 2009 | 05:43 PM
I bought these to run for now, I want to get a setup with slicks for next year. My friend said he will buy these off of me after I run them this weekend, so no big loss!
I bought MT ET DR's 205/40/17. It was a toss up between those and 225/45 BFG's. The few people I talked to said to go with the MT's over the BFG's.
I dont plan on doing any NLS except for the 3-4 right at the end of the track, should be ok doing just that right? Thanks for the warning tho Steddy!! I usually never NLS with the tune unless Im at the track. I guess it's only a matter of time before **** goes wrong tho!!
Im going to start with 20psi in the tires and a 4K launch with a quick slipping action on the clutch, def not dumping it LOL!!
Old Nov 12, 2009 | 07:02 PM
Maxim_X's Avatar
Don't do a huge burnout. You cant drop-clutch-launch like you would with a slick. Roll out with the clutch and motor @ 2500 and let her have it when the clutch is engaged.
Judging by your trap speeds, with your power, they should hold though first gear. If you actually make 372whp, however unlikely, your going to have trouble keeping the tires from lightting up no matter how soft you launch.
Old Nov 12, 2009 | 07:12 PM
Bumpin Balt's Avatar
What he said!^^^ Dumping the clutch on DR's will have you crying on the tow truck ride home! lol
Old Nov 12, 2009 | 07:52 PM
I dont really make that power LOL... Its a inside joke (322/391 for real, altho its prolly around the 330mark right now)
