Drag Racing Kindle Racing and Dalcorp Racing
Launching with DR's
Old Nov 12, 2009 | 10:37 PM
mongorat427's Avatar
Originally Posted by VeNoM0713
wow, i have that same problem.. ever since i got my spec 3+ clutch installed my car hates the 1-2 shift.. its like i have to force it to go in and sometimes that doesnt even work.. its only the 1-2 shift also and its only at the higher rpms like you were saying. how did you fix it?
Im going up to the track this weekend to see if I can figure out whats up with the 1-2 shift. I might have to Mongo it to see if I can get it to go in. I just got my new Trifecta Dual Tune and and installed my OTT stage 2 mounts today. It feels real strong from 4500 to 6500 RPM so I want to do 1-2 around 6300 rpm so it dosnt drop below 4500 rpm . Ill post the results or the pictures of the pieces of my trans. HaHa
Old Nov 13, 2009 | 06:26 AM
ralliartist's Avatar
Originally Posted by BYT*SS*TURBO
I dont really make that power LOL... Its a inside joke (322/391 for real, altho its prolly around the 330mark right now)
inside jokes like that are gay.
__________________________________________________ ___________
To all, every car is different, powerbands, mod list, tunes, the conditions at the track, how the car will respond, they are all different. It's going to take some testing on a few different passes to find the right tire pressure and the right launch technique to get it.
Last edited by ralliartist; Nov 13, 2009 at 06:26 AM. Reason: Automerged Doublepost
Old Nov 13, 2009 | 08:51 AM
BYT*SS*TURBO's Avatar
I actually post my dyno graphs, you can find it in the dyno thread if you like
Old Nov 13, 2009 | 09:10 AM
383_Stroker's Avatar
If its the same seal: Follow the line from the master cylinder down to the trans (you'll likely have to remove the fusebox to have access). Unhook it. I think there's like a 90* elbow on top of the trans (or maybe its made into the end of the line, i can't remember) and you pull that off. Then there's just a nipple sticking up and it should have a seal that SNAPS down onto it.. Mine was just sort of sitting on top, not snapped into the groove. Snap it down, reassemble
Old Nov 13, 2009 | 09:15 AM
I'm just saying.
Old Nov 13, 2009 | 09:23 AM
Glad you voiced your opinion lol..
Old Nov 14, 2009 | 08:57 AM
DR's show up Monday. Im going to try and hit my local track Friday night to get some test runs on them before the event on Sunday.
Thanks everyone for the suggestions
Old Nov 14, 2009 | 10:28 AM
beast10007's Avatar
CANT wait to hear what you got!
Old Nov 14, 2009 | 12:56 PM
cmiller8006's Avatar
Your going to have to watch wheel spin big time. If I remember those are like 23.5 inch tall, which also means shifting to forth but thats a good thing in my oppinion.
Old Nov 14, 2009 | 01:09 PM
Preston's Avatar
give her the beans!
Old Nov 14, 2009 | 06:06 PM
  #36
FutureEcotecOwner's Avatar
Like everyone else is saying, DR's are in-between street tires and slicks, which is a good thing. I wouldnt launch from that high of an RPM, it just isnt worth it I dont think, unless you know exactly what you're doing. Your local track might be good for practice, but I wouldnt expect the same results from Atco. My Brother runs consistent 8.9's at our local track, and today at Bowling Green he ran consistent 8.6's, on the same setup, except losing boost in 2nd and 3rd. Results will very from track to track. Report back with some good times, and good luck.
Old Nov 14, 2009 | 08:18 PM
  #37
I think he's better off with slicks than DR's.
Old Nov 14, 2009 | 11:28 PM
  #38
I do to, but there are alot of people who dont wanna downgrade brakes. I will be doing that however next Spring though.
Old Nov 15, 2009 | 01:18 AM
  #39
OntarioKev's Avatar
Will the stock LNF clutch hold a quick slip, followed by the traction of the DRs with that much tq? Or will the heat from the quick slip be just enough extra strain on it to have it slip for half of the run?
Kevin
Old Nov 15, 2009 | 02:06 AM
  #40
Kevin
Well I dont slip the clutch but it has held up fine to the slicks so far.
RaginChopsuey
Oct 27, 2015 01:27 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
JonyyB
Mar 13, 2013 11:50 PM
b-spot
May 16, 2005 08:44 PM
