return Policy?
Old Nov 12, 2009 | 07:01 PM
Jimmys2007CobaltSS/C's Avatar
return Policy?
Hi I just ordered a stage 2 belt and apparently it don;t fit cause I have a 2.4 ss and it's stage 2 supercharged and I need a 5 rib belt which the shop ordered for me. I order it on Monday morning through credit/debit, can I get return it for a refund?
Old Nov 12, 2009 | 11:00 PM
mtbrent's Avatar
I'd be impressed if your "shop" found a 5 rib belt that fits. I've researched and cross referenced numbers online for hours and hours with nothing even NEAR the size needed in a 5 rib to fit sc'd 2.2/2.4. Only thing to do is cut 1 rib off lsj belts. If your new belt actually works, I know there would be many people interested on here, so post up some numbers!
Old Nov 14, 2009 | 03:02 PM
Jn2's Avatar
Jn2
As posted above. The belt u ordered is correct. U have to cut a rib off. Ur shop prob ordered a belt based on lenght. Not knowing it's a double sided bel u need. U can cut a rib off a 6 rib belt and be fine. I
running a 2.8" on my 2.2 with a stg2 belt with a rib cut off fine
ashalle2
Sep 27, 2015 03:28 PM
90white240
Sep 14, 2015 09:51 AM
Josh@ottp
Sep 8, 2015 10:18 AM
Turbo6
Aug 27, 2015 08:37 PM
