read me and respond damn it! =D
Old Nov 16, 2009 | 03:37 PM
c0baltsssc06's Avatar
Exclamation read me and respond damn it! =D
Ok I have been reading threads after threads about chainging trannie fluid... I drive a 2006 cobalt ss supercharger. All the treads I've seen go back and forth about what's the best to use... I was thinking about going wth the royal purple but just want to conferm... I don't wanna **** anything up. Thanks for replys!
Old Nov 16, 2009 | 03:39 PM
D4u2s0t's Avatar
do you have an owners manual?
stacy_dammit's Avatar
i'd like 2 knw 2
Old Nov 16, 2009 | 03:42 PM
Nope.. I've read the manual says aft or some **** like that.. but then they say to go wth royal purple. But then people say it fks wth the trannie
Old Nov 16, 2009 | 03:58 PM
383_Stroker's Avatar
yep, 06 manual says automatic trans fluid..
GM Syncromesh or Royal Purple Syncromesh..
Old Nov 16, 2009 | 04:00 PM
K ima prob go wth royal purple
Old Nov 16, 2009 | 04:03 PM
D4u2s0t's Avatar
autoamtic transmission fluid.
Old Nov 16, 2009 | 04:09 PM
valentino0214's Avatar
i used royal purple... got no complaints
Old Nov 16, 2009 | 04:16 PM
arkkornkid's Avatar
Saturn Manual Transmission Fluid part #21018899
Old Nov 16, 2009 | 04:50 PM
Just picked up 2 bottle of royal purple max gear high performance gear oil sae 75w-90
JPizzle's Avatar
75w-90??????? Don't put that in your oil reservoir
Old Nov 16, 2009 | 04:53 PM
Aww but I wanna lol
Old Nov 16, 2009 | 04:56 PM
Collin's SS's Avatar
DONT USE RP!!! use only oem fluid or redline 75w90NS. i use 75w90NS in my 06 ss/sc works great!!
Old Nov 16, 2009 | 04:58 PM
Omg yawl r driving me nuts lol I alredy bought the rp
Old Nov 16, 2009 | 05:00 PM
dvscobaltSS's Avatar
yeah i would just stick with the regular oem from dealer. i took mine to a tranny place to look at a leak i had and they said they RP was burned to hell. i only had it in for a couple months
Old Nov 16, 2009 | 05:40 PM
Any1 else? Lol I don't no what to do.
Old Nov 16, 2009 | 05:47 PM
arkkornkid's Avatar
you'll get all kinds of people telling you to use this, not that: as such I still recommend the oem stuff..... but it's up to you on what you want to use.
I'll offer a tip: remove or loosen fill plug before drain plug, just in case it strips you won't be left with an empty transmission
Old Nov 16, 2009 | 05:56 PM
bmb17's Avatar
I would just use OEM then you know your good!!
Old Nov 16, 2009 | 06:06 PM
slowswap's Avatar
Okay did some searching and found this post from Maven.
Originally Posted by Maven
Yes, I know they use Casrol fluid. Its Castrol 0063 for the 05-07, which is 75w90, and while they may use or call it GL4 in Europe for Opel, here its widely accepted that GL5 is the preferred fill. Many GL5s meet/exceed GL4 specs, 75w90 GL4 isnt any easier to find either so its really a moot point. Not to mention that GL5 is the better choice for higher speed operation.
08/09 TCs actually use a different fluid, Castrol 0402, a 75w85 ,which is a GL4 fluid, but in its absence a non friction modified GL5 is the best choice.
Old Nov 16, 2009 | 11:34 PM
Ahh thanks.... it will work fine then.
Ok I had a problem. I tryed 4 a while and it didn't budge, id turn it counter clockwise right? I didn't strip it or anything. I'm just gonna try n the moring again whale there's light
Last edited by c0baltsssc06; Nov 16, 2009 at 11:34 PM. Reason: Automerged Doublepost
Old Nov 16, 2009 | 11:49 PM
ajm5036's Avatar
Subscribed.
When did most of you change your tranny fluid?
Old Nov 16, 2009 | 11:58 PM
cobalt123's Avatar
use dry sand
Old Nov 17, 2009 | 08:46 AM
Originally Posted by cobalt123
use dry sand
How would that help? Lol
Old Nov 17, 2009 | 11:12 AM
Maven's Avatar
Royal Purple 75w90 Max gear is a bad choice. Its exactly what i recommended not using in that quote Slowswap made......its a friction modified oil. you want a NON friction modified oil.
Use the stock stuff (21018899) or Redline 75w90NS, I know there are a small group of guys that are trying Redline MTL with good results (so far) but I have never used it.
Oct 27, 2015 01:27 PM
Tupp
Sep 30, 2015 08:18 PM
dennis69
Sep 28, 2015 02:16 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
