How loud is the blow-off vavle on the Cobalt SS?
Old Apr 18, 2005 | 06:14 PM
cmersits's Avatar
I was just wondering how loud the blow-off valve on the Cobalt SS supercharger is. Is it really loud or kind of on the quite side? Because a friend of mine has a some SE Jetta that comes stocked turbo and the blow-off valve isn't that loud, it sounds kind of wimpy.
Old Apr 18, 2005 | 06:28 PM
tiny's Avatar
it doesnt have a blow off valve
most superchargers dont, *most*
and at a low psi that they run at. its not really needed
Old Apr 19, 2005 | 12:29 PM
c0baltss2005sunburst's Avatar
I talked to someone about putting one on before I really had much information on superchargers, and I guess it's actually just more work that necessary, and it doesn't really do much for it. They're mainly needed on turbos.
Old May 1, 2005 | 12:31 AM
dnbguy86's Avatar
Well, on most factory boosted vehicles they dont use blow off valves. those are mainly aftermarket equipment. they use bypass valves that are used with vacuum lines and such, a lot cheaper than installing a bov on every car.
Old May 1, 2005 | 10:52 PM
Voodoosoup's Avatar
THe Supercharger on the SS has a bypass valve that is controlled from the coputer by a solenoid to open ans limit boost to 12 or 12.5 psi.......
Old May 2, 2005 | 12:18 PM
Well your partly right.
Rootes based superchargers don't need a BOV because the throttle plate is before the blower. So when you let off the gas the throttle plate closes and no air gets to the compressor to create any boost. So there is no excess boost to that needs to be vented.
Most of the time cruising on the hiway at lower throttle the boost guage is at negative 10-20. Open the throttle and it hits 7-12.5 almost instantly.
Old May 2, 2005 | 12:24 PM
ToxicPoison's Avatar
http://auto.howstuffworks.com/question122.htm
Good stuff on there. Theres also a good article on differentials (Open, LSD, etc)
Old May 8, 2005 | 04:44 AM
homewrecker's Avatar
The Blow Off Valve & Compressor Bypass Valve (CBV's) terminologies are often used interchangeably. Ie. My talon came with a CBV stock but is most commonly referred to as a BOV.
Aftermarket BOV's also use vaccum lines to actuate the diaphragm - for turbos anyway.
Old May 8, 2005 | 06:44 AM
tiny's Avatar
recirc>bov
Old May 9, 2005 | 10:07 PM
Speed Mafia's Avatar
yes it is all the same concept is to vent air when letting off the throttle when under boost to releave the pressure in the intake system...
i get so use to calling bypass valves the same as BOV and it is a bad habbit but it is all the same and yes on roots they use a plate system...
on turbo and centrifigul blower they are bypass valve (when stock) and BOV when modded and higher boost. also when driving around the motor is in vaccumm and keeps the bov/bypass venting air and when WOT the vaccuum is lost closing the BOV/bypass and creating boost...
Most cars will run 22-15 Hg in vaccuum when driving around in part throttle. now on a NA motor you motor will say at 0 hg/boost in the WOT runs
Old May 22, 2005 | 06:35 PM
JapEatr's Avatar
South Central *********
that is because the throttle butterfly is open...ie no vaccum, all air
Old Dec 22, 2005 | 12:50 AM
HMFDZ28's Avatar
The By-pass valve on your M62's are to reduce parasitic drag. When you are not giving the car throttle the bypass opens up so the charger only requires about 1/3 hp to spin. Making the motor more efficent out of boost. On the Cobalts they electornically controlled it in order to keep you from raising the boost levels. Keep it at what they feel to be a safe level.
Old Dec 26, 2005 | 02:01 AM
Mercury's Avatar
Old Dec 26, 2005 | 10:09 AM
cvenom2122's Avatar
Thumbs up
"slaps head"
Old Jan 3, 2006 | 02:18 PM
Brian MP5T's Avatar
They are basically the same but because of where they vent to it's a good practice to keep the names seperate
By-Pass will vent back into the intake after the Air Filtrer
Blow-Off will "Blow Off" out of the intake system.
Old Jan 4, 2006 | 02:32 AM
IonNinja's Avatar
only ricers care about how loud a BOV is
Old Jan 4, 2006 | 08:35 AM
Brian MP5T's Avatar
Or people such as myself who just love driving a car that has no sound killing so every little noise in the car is heard. It's like music to me...
Old Jan 4, 2006 | 08:51 AM
Badmunky's Avatar
Nice looking setup man.
Old Jan 4, 2006 | 09:03 AM
R33P3R007's Avatar
360 L337 User
dude, the blowoff on the ss is crazy...
Old Jan 4, 2006 | 09:04 AM
R33P3R007's Avatar
360 L337 User
its like... vroooooomm SPOOOOOOOOSH!!!! vrooooooooom SPOOOOOOOOSH!!!!
it's crazy!!!!!!
Old Jan 4, 2006 | 09:47 AM
Brian MP5T's Avatar
Thanks, It's easy to keep clean if you never drive in the winter. It took a couple of years to get it to this point...
Old Jan 5, 2006 | 01:21 AM
IonNinja's Avatar
you ricer! wheres your Twin SSQ RFL BOV?
my original comment was directed at people with boosted cars who go out and buy the loudest BOV they can find as their first mod just so they can have the cool sound.
Old Jan 5, 2006 | 01:28 AM
CobaltSS422's Avatar
it's crazy!!!!!!
Old Jan 5, 2006 | 09:07 AM
Brian MP5T's Avatar
Kewl...
Old Jan 5, 2006 | 10:31 PM
FastFrontier17's Avatar
roots type chargers dont use a blow off valve...they dont build boost that way... they have a bypass valve to...which is good, it means your car will run like it was NA...and then it closes when you floor it...and BOOOOSSSSSTTTTTTT
