Forced Induction Turbos/Superchargers
How loud is the blow-off vavle on the Cobalt SS?
Old Jan 6, 2006 | 08:07 AM
Brian MP5T's Avatar
Originally Posted by FastFrontier17
roots type chargers dont use a blow off valve...they dont build boost that way... they have a bypass valve to...which is good, it means your car will run like it was NA...and then it closes when you floor it...and BOOOOSSSSSTTTTTTT
That valve could be allowed to vent rather than Re-Circ but that would sound cool but be really dumb.
Basically...
You want TURBO sounds... Go Get a Turbo...
Old Jan 21, 2006 | 03:41 AM
Tripy's Avatar
Basically...
Or get a centrifugal SC
Old Jan 21, 2006 | 12:51 PM
speed's Avatar
or get this
http://www.sunamiturbo.com
Old Feb 26, 2006 | 10:15 PM
fiShYs-'s Avatar
what is the purpose of blow off valve anyways? is it just a wastegate that make a sound?
Old Feb 26, 2006 | 10:23 PM
SSJBaku's Avatar
Originally Posted by speed
that has to be one of the funniest things ive seen in a while!!
Old Feb 26, 2006 | 10:26 PM
italstalnprd86's Avatar
Originally Posted by tiny
it doesnt have a blow off valve
most superchargers dont, *most*
and at a low psi that they run at. its not really needed
most is right..... only centrifugal superchargers, or a boost source before the throttle body needs them.... since on the ss, the throttle body is first, they are pointless. The main purpose of a blow off valve is to bleed off boost after the throttle is in the closed position, this allows the boost to escape, rather than back up into the turbo, they basically prolong the life of the turbo, by releasing the pressure, rather than the pressure comming back to the turbo.....
Old Feb 26, 2006 | 10:27 PM
SSJBaku's Avatar
vent excess boost to protect the engine either recirc or open
Old Mar 12, 2006 | 01:57 AM
plyboy-illest's Avatar
does not have a BV it has a nice whine to it tho
Old Mar 12, 2006 | 07:24 AM
Brian MP5T's Avatar
Vent Charge Pressure in a TURBO setup to maintain the Spool and Kill Lag between Shifts.
A Wastegate is a completely diferent part.
Old Mar 12, 2006 | 07:25 AM
Brian MP5T's Avatar
The SS SC DOES have a BPV.
breds2k
19
Sep 21, 2015 10:24 AM
OrangeK
Sep 20, 2015 03:02 AM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
Infamous SC/SS
Sep 4, 2015 05:33 PM
Adam144
Sep 3, 2015 07:48 PM
