Forced Induction Turbos/Superchargers
Any tuning packages for 2.2l turbo
Old Feb 20, 2006 | 10:49 PM
CobaltSS1's Avatar
Alright i am dead set on buying the maximumboost stage 2. I have the money in hand. Is there any MIC packages available, or even just chips available? I plan on pistons, rods, and new bolts eventaully but iwant to be able to run 7-8psi for alittle while til i drop the money for the bottom end. Any ideas?
Old Feb 20, 2006 | 11:54 PM
boosted2.2's Avatar
Well you could try and wire a megasquirt(the route i'll probably go). an saf-c, or the cheap-o band-aid fmu. Anyway you go, I'd deffinetly get a wideband. The only problem with the fmu is, alot of eco's are having problems with the motor not having an open loop mode.
Old Feb 20, 2006 | 11:55 PM
IonNinja's Avatar
I wish it was just as easy as picking up an MIC. You can thank GM for not being able to chip your car, you would have to use some type of piggy back, although I'm not sure which one would work. There are no aftermarket maf's either and I'm not sure you'd even have to replace that. And injectors come with the stage 2 kit right or am I wrong?
Basically, no MIC packages.
Old Feb 21, 2006 | 10:12 AM
celicacobalt's Avatar
look for a tuning device called an smt-6, a couple ss/sc have been using it and is supposed to be the best thing out at the moment.
Old Feb 22, 2006 | 10:51 PM
Shamrock's Avatar
http://www.perfectpower.com/products/smt6.asp
Old Mar 10, 2006 | 05:55 PM
zinner's Avatar
Moderator Alumni
port fueler is what you need. The hahn performance people make that.
Old Mar 12, 2006 | 10:22 PM
maximum boost kit sucks
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
reybalt
Sep 25, 2015 08:28 PM
