Any tuning packages for 2.2l turbo
Alright i am dead set on buying the maximumboost stage 2. I have the money in hand. Is there any MIC packages available, or even just chips available? I plan on pistons, rods, and new bolts eventaully but iwant to be able to run 7-8psi for alittle while til i drop the money for the bottom end. Any ideas?
Well you could try and wire a megasquirt(the route i'll probably go). an saf-c, or the cheap-o band-aid fmu. Anyway you go, I'd deffinetly get a wideband. The only problem with the fmu is, alot of eco's are having problems with the motor not having an open loop mode.
I wish it was just as easy as picking up an MIC. You can thank GM for not being able to chip your car, you would have to use some type of piggy back, although I'm not sure which one would work. There are no aftermarket maf's either and I'm not sure you'd even have to replace that. And injectors come with the stage 2 kit right or am I wrong?
Basically, no MIC packages.
