AEM Wideband O2 Gauge Kits...In Stock!
GREAT for those who are tuners and/or need to monitor all of their engine's performance AFR. We have these back in from back order. Some info:
(Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!)
"SIX-IN-ONE GAUGE-TYPE UEGO CONTROLLER"
24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda (11.0:1 to 17.0:1)
Integrated three-digit display reveals AFR or Lambda in real time (10.0:1 to 18.5:1)
User-selectable 0-5v analog output included for use with data loggers and most programmable engine management systems
NEW! Switch between AFR or Lambda readout with a twist of a switch (included face plate change is required for proper readout)
NEW! Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!
NEW! Quick-Connect system eases installation by allowing users to mount the gauge and sensor wiring separately
Ideal AFR monitoring tool for carbureted applications and engine dynamometers
Does not oscillate AFR like narrow band sensors
Serial data stream included for output of AFR (RS 232)
Accurate to 0.1 AFR
Bosch UEGO sensor included
http://dezod.com/pd_aem_singlechannel_uego.cfm
Accurate to 0.1 AFR
Originally Posted by 06black
dam i sooo want one fo thosue but theres no way in HELL i'm payin $306
you can get them for around the 200-220 mark.
yea i'm with you on that one!!!!
to may bad stories ALSO i WAS mistaken about prices i had been looking at.
my appologies about that and now that i've done some serious looking the $300 is a DAM good price!!!
ahhh dam i got order one of these things i've got my snazy gauge piller with an empty spot.
you still have these in stock?
Dammit, now I need a gauge pillar - I forgot about that one
Thanks alot DEZOD! You guys have great service, even for us overseas knuckleheads who can't get right.
Originally Posted by patathSS
Do you have any just display gauges? I have an LC-1 and I would like to wire a seperate display gauge to it. Do you guys stock Innovate stuff? I was looking for the XD-16 gauge. Thanks!
