INTENSE-Racing.com Intense Racing is a proud Supporting Vendor
PCM question
Old Jun 7, 2006 | 11:29 PM
phxSS's Avatar
PCM question
Do you guys no longer use the piggyback ECU? I was reading on your website that you use GM's new code that came out, then make some changes to it. My question is, is the code you guys use the same one used in the GM stage 1 and 2 kits?
Also, I'm not sure I'm seeing what's included in the kits. Is it the list of items highlighted in yellow at the bottom of the screen?
Old Jun 8, 2006 | 04:54 AM
cashstacker's Avatar
will you guys sell a stage 3 pcm? I'm interested in buying injectors and pcm but I already have the pulley im running a 3 in so I thinks stage 3 would work since I boost 15lbs.
Old Jun 8, 2006 | 08:14 AM
Rogue's Avatar
We do sell the PCM's seperately, please check out the LSJ Electronics section. We no longer use MAF-T's but we do not start with GM's Stage codes, we start with the latest stock PCM code available for your PCM (Occasionaly, GM has updates for particular vehicles) and tune from there. If you already have the GM S1 or S2 PCM you can send it in and we can tune on top of it if you wish.
Old Jun 9, 2006 | 01:30 AM
phxSS's Avatar
Ok, so the items highlighted in yellow at the bottom of the screen on the stage kits area are not included in the kit? If not, where do you have a listings of what exactly comes in each kit?
Old Jun 9, 2006 | 01:42 AM
CobaltSS422's Avatar
if you go to www.intense-racing.com and go to store and then LSJ and down to performance pkg. it lists all stage kits and then inside that it shows what comes with that stage kit
Old Jun 9, 2006 | 03:06 AM
max_boost's Avatar
I have a PCM tuning question too. It doesn't really matter, but I got to thinking about it and am curious if you can tune the ecu without it being in a car, and how it's done. I that is propreitary info I don't expect you to give it out. I was just wondering.
brandon04
Oct 21, 2015 07:04 AM
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
