Gravana Tuning Gravana Tuning is a proud Supporting Vendor
Gravana 2.0 SC Header Pre-Sale
Old Jul 14, 2006 | 08:51 PM
Gravana1's Avatar
You asked and we delivered! Gravana is now taking pre-orders for the Pacesetter 2.0 Headers. Available in both Ceramic Thermal Heat Barrier Coating and Painted.
CLICK HERE TO ORDER
Armor-Coated
The Pacesetter 4-into-1 Header is manufactured using 1-3/4" mandrel-bent, mild steel tubing and surface-ground, thick steel flanges. This header includes a flanged 3-inch collector, hook-ups for smog & engine management sensors, and a header extension to connect to stock exhaust system. This header includes the Armor*Coat finish, a 2000-Degree, metallic-ceramic coating that is polished for the ultimate in style & performance. The Armor*Coat is impervious to discoloration like paint, chrome or dull finish coating. Additionally, it reduces engine bay temperature, resists rust and corrosion, and is easy to keep clean. Includes all necessary hardware, gaskets and illustrated instructions, and is backed by a 3-year warranty. Header bolts not included. In some cases, fabrication may be required. For installation, you will cut the pipe right at the cat , insert the Pacesetter 3" extension, and weld it on. Any qualified welder should be able to handle this job with ease!
CLICK HERE TO ORDER
Black Painted
The Pacesetter 4-into-1 Header is manufactured using 1-3/4 inch mandrel-bent, mild steel tubing and surface-ground, thick steel flanges. This header includes a flanged 3-inch collector, hook-ups for smog & engine management sensors, and a header extension to connect to stock exhaust system. This header includes a black painted finish to help reduce engine bay temperature and corrosion. Includes all necessary hardware, gaskets and illustrated instructions, and is backed by a 3-year warranty. Header bolts not included. In some cases, fabrication may be required. For installation, you will cut the pipe right at the cat , insert the Pacesetter 3" extension, and weld it on. Any qualified welder should be able to handle this job with ease!
CLICK HERE TO ORDER
PRE-ORDER NOW TO GET LOCKED-IN ONE OF THE FIRST SETS TO BE SHIPPED! We do NOT charge your credit card until we ship! ETA to ship is tentatively mid-August. Check our website for updates.
CLICK HERE TO ORDER or email us at info@gravanatuning.com
Old Jul 14, 2006 | 10:49 PM
fiShYs-'s Avatar
how much hp does this increase?
is this just a direct replacement of stock exhaust manifold with no extra modification?
this comes with all necessay gaskets and bolts if needed?
Old Jul 15, 2006 | 12:52 AM
selfinfliction's Avatar
probably about 10-12whp depending on the dyno.
a header will go a long way in our cars. cause the stock manifold is extremely restrictive
Old Jul 17, 2006 | 10:32 AM
Ern's Avatar
Ern
Weld? Looks like it has flanges for a bolton. I want something I can bolt together to my magnaflow exhaust and whatever downpipe I get.
HEATON
Oct 16, 2015 07:21 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 28, 2015 12:51 PM
z28addiction
Sep 28, 2015 12:03 AM
