Nitrous Oxide N20
Nitrious Questions
Old Aug 11, 2006 | 08:39 PM
Knightrider22's Avatar
Nitrious Questions
Hey guys im going to be going N20 soon and just wanted to know what was the best kit for our cars....i herd that the Nx wet kit is really good...and also is there a switch that i can turn on when i want to use the nitrious or do i have to turn the bottle on itself...cause i just want it to spra when im at WOT...but only when im racing...not when im trying to go around someone in traffic lol.
Old Aug 11, 2006 | 10:28 PM
IonNinja's Avatar
https://www.cobaltss.net/forums/show...37&postcount=3
Old Aug 11, 2006 | 10:47 PM
SPLATT's Avatar
well most if not all nitrous systems come with a WOT switch. Also, as far as it not spraying all the time...you wont have to worry about that either. haha. check out the link ionninja posted, some good stuff there
Old Aug 13, 2006 | 12:56 PM
when you say two step colder plugs do you mean from stock??? cause i have the autolites that come with the Intense stage 3 kit...so you want me to go two colder that that?
Old Aug 13, 2006 | 06:15 PM
IonNinja's Avatar
no thats two steps colder than stock
if you've got the stage 3 kit you probably already have 2 step colder plugs
Old Aug 13, 2006 | 06:19 PM
StinkBOMB's Avatar
I've got those plugs, I think they're only 1 heat range colder than stock.
Old Aug 13, 2006 | 06:21 PM
StinkBOMB's Avatar
Yeah, says so on the site.
The stock spark plugs for the LSJ motor are NGK PFR6T-10G platinum plugs. Platinum and iridium plugs are much harder and more expensive metals that can last up to 100,000 miles however they are not the best metal for heat dissipation. In our experience copper based plugs are far superior in supercharged applications and while they may not last as long as platinum or iridium plugs they will offer better performance. In addition to being copper based these plugs are also one heat range cooler than stock which helps reduce the possibily of detonation and the resulting knock retard.
I think the NGK's are the ones two ranges colder.
brandon04
Oct 21, 2015 07:04 AM
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
