Nitrous Oxide N20
Progressive Nitrous Controllers
Old Sep 25, 2006 | 10:16 AM
Sw4y1313's Avatar
Im about to buy the NOS Wet kit off of Cobalt-Addiction(best price i have found yet on a wet kit), and would like to get a progressive controller. I have found a couple, but most are VERY pricy. The one that seems to be the most reasonable is the Mini 2-Stage Progressive Nitrous Controller. I just wanted to check and see if this is a good buy or not. It has a built in Window switch as well. This would eliminate the WOT switch as well right?
The reason I want a progressive controller is so i dont put that instant strain on my engine. With a progressive shot, wouldnt you be able to set the RPM to engage the nitrous lower then 3k because its not an instant 50shot?
Old Sep 25, 2006 | 10:35 AM
CTCOBALTSSS's Avatar
The progressive controller sounds like a good idea.
Old Sep 25, 2006 | 11:16 PM
Sw4y
Guest
Posts: n/a
Has anyone used them that can comment on them? The Mini 2-Stage Progressive Nitrous Controller is legit right? for 220 bux you cant beat it.
Old Sep 26, 2006 | 05:30 PM
slowion2's Avatar
the Jacobs unit works well in my experience, must make sure that the solenoids are designed for pulsing, that's how the system works.
the "strain" is still going to be there as nitrous is a more violent combustion by nature, but it will be in shorter bursts as opposed to one long one. honestly, it's not really needed for that concern. the only people that really utilize these controllers are those that run a large shot and need it for traction reasons.
Old Sep 26, 2006 | 07:12 PM
Sw4y
Guest
Posts: n/a
Running a 50 shot, i shouldnt destroy my engine after a bottle or so right?
Old Sep 26, 2006 | 08:51 PM
slowion2's Avatar
not even close, I've run a 75 for well over a year of frequent use
you may want to go and research more about nitrous, if you had you would already have answers to most of your questions.
Old Sep 30, 2006 | 11:02 AM
Blububble's Avatar
waste of money! those are for racing setups running 150-300 shot. a controller is NOT necessary for a tiny 50 shot.
Old Sep 30, 2006 | 11:25 AM
slowion2's Avatar
exactly
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
Sep 26, 2015 06:44 PM
Coballin13
Sep 25, 2015 08:43 AM
