Progressive Nitrous Controllers
Im about to buy the NOS Wet kit off of Cobalt-Addiction(best price i have found yet on a wet kit), and would like to get a progressive controller. I have found a couple, but most are VERY pricy. The one that seems to be the most reasonable is the Mini 2-Stage Progressive Nitrous Controller. I just wanted to check and see if this is a good buy or not. It has a built in Window switch as well. This would eliminate the WOT switch as well right?
The reason I want a progressive controller is so i dont put that instant strain on my engine. With a progressive shot, wouldnt you be able to set the RPM to engage the nitrous lower then 3k because its not an instant 50shot?
the Jacobs unit works well in my experience, must make sure that the solenoids are designed for pulsing, that's how the system works.
the "strain" is still going to be there as nitrous is a more violent combustion by nature, but it will be in shorter bursts as opposed to one long one. honestly, it's not really needed for that concern. the only people that really utilize these controllers are those that run a large shot and need it for traction reasons.
