Modern Performance Modern Performance is a Supporting Vendor
contacts: Modernceo
2.6 - 3.25 blower pulley with interchangeable hubs now in stock at MP !
Old Oct 5, 2006 | 12:37 PM
Modernceo's Avatar
Modern Performance proudly introduces a line of pulleys for the Cobalt SS Supercharged, and Ion Redline supercharged.
These pulleys are unique, because this pulley system has a unique interchangeable outer pulley that mates onto a fixed hub.
This makes changing pulleys very easy because you just mount the hub once, and then you can change the pulley with four allen key screws ! Its that simple !
Now, these pulleys come in two options.
First, you should buy one of the pulley systems consisting of a hub, and pulley. Choose your size pulley youd like and we'll send you a package of both called the DUB system, or dial your boost system.
There are two pulleys available, a standard pulley, which is great for 2.8 - 3.25 size pulleys, and then theres whats called the non slip pulley which has a unique design that maximizes traction of the pulley belt for maximum boost ! The non slip pulley is available in all sizes, from 2.6 all the way up to 3.25 size, and is slightly more in price depending on which size pulley you choose.
For Increases in Boost over the Factory (3.50 " Outer Diameter) - Actual 3.35" size, the following pulleys sizes are calculated to increase boost levels above stock 12 psi:
- For a 1 to 1.5 lb. Increase in Boost over the Factory 3.35", use the DUB 3.25" SC Pulley System
- For a 2 to 2.5 lb. Increase in Boost over the Factory 3.35", use the DUB 3.10" SC Pulley System
- For a 3 to 3.5 lb. Increase in Boost over the Factory 3.35", use the DUB 3.00" SC Pulley System
- For a 4 to 4.5 lb. Increase in Boost over the Factory 3.35", use the DUB 2.90" SC Pulley System
- For a 5 to 6 lb. Increase in Boost over the Factory 3.35", use the DUB 2.80" SC Pulley System
Here are the options:
Dub system pulley and hub $139.99
Extra pulleys $64.99
Dub system with NON SLIP pulley 3.25 - 2.8 inch size $149.99
Dub system with NON SLIP pulley 2.7- 2.6 inch size $159.99
Extra pulleys 3.25 - 2.8 inch size $79.99
Extra pulleys 2.7 - 2.6 inch size $84.99
Old Oct 5, 2006 | 12:44 PM
Rangerondubz's Avatar
Thats a nice design on those non-slip pulleys, I would have never thought something like that would have stopped belt slip!
Old Oct 11, 2006 | 01:06 PM
cashstacker's Avatar
too bad I didn't know about this sooner... I just got mine in the mail...
DarrenGC
Forced Induction
Jan 2, 2016 09:10 PM
Builttss
Oct 4, 2015 10:21 AM
cw383
Sep 30, 2015 12:41 AM
Bohb
Sep 27, 2015 09:11 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
