Cruise control not working...
Well, my first official problem with the car. My cruise control just decided to take a crap and is unresponsive when the button is pressed. If I press the button continuously it will flash "cruise enabled" but then quicky dissappear without engaging. Anyone else having this issue? It sucks really badly because I am currently in Columbus visiting friends and have a 4 hour drive ahead of me tomorrow...figures.
I have the same problem too. It started a few weeks ago. I took my car to the shop to have them check it out. They told me it is a faulty switch. They couldn't replace it because the damn thing is still on national backorder. You'll just have to deal with it until the part comes out. And I feel for you about the drive. I had to make a 7 to 8 hour each way drive without cruise last month.
My car did this to me after reading some one elses post on it a few weeks back, i stopped and ate lunch for a lil bit and left and it worked so maybe turn your car off and back on or you can try to dis connect the battery. or check fuses. something gotta work.
This is a common problem with tons of posts regarding it. There are couple of things that can cause this:
1. The switch on the clutch pedal is bad.
2. The cruise control buttons or the cruise control itself is not working.
3. Most likely - you are driving with your foot on the clutch. This causes the car to throw a code because the clutch pedal always has pressure on it. You have to have the code cleared then the cruise control will work again. However if you still keep driving with your foot on the clutch the code will come right back.
You are most likely riding the clutch and it activates a clutch malfunction code. I had the same problem and onstar let me know what was wrong. I took it to the dealer and they cleared the code and it hasnt happened again.
Well I got it fixed, it ended up being a clutch adjustment. I wasnt riding the clutch at all, I was actually pulling the clutch back towards me trying to get it to work at one point lol. At least it was an easy fix...
