Cruise control not working...
Old Nov 3, 2006 | 03:02 AM
watersedge1234's Avatar
Well, my first official problem with the car. My cruise control just decided to take a crap and is unresponsive when the button is pressed. If I press the button continuously it will flash "cruise enabled" but then quicky dissappear without engaging. Anyone else having this issue? It sucks really badly because I am currently in Columbus visiting friends and have a 4 hour drive ahead of me tomorrow...figures.
Old Nov 3, 2006 | 03:11 AM
racinthor's Avatar
I have the same problem it just started this weekend.
Old Nov 3, 2006 | 03:18 AM
domin8_gt's Avatar
I have the same problem too. It started a few weeks ago. I took my car to the shop to have them check it out. They told me it is a faulty switch. They couldn't replace it because the damn thing is still on national backorder. You'll just have to deal with it until the part comes out. And I feel for you about the drive. I had to make a 7 to 8 hour each way drive without cruise last month.
Old Nov 3, 2006 | 03:47 AM
Killa SS's Avatar
My car did this to me after reading some one elses post on it a few weeks back, i stopped and ate lunch for a lil bit and left and it worked so maybe turn your car off and back on or you can try to dis connect the battery. or check fuses. something gotta work.
Old Nov 4, 2006 | 02:19 AM
racinthor's Avatar
checked my dtc codes and found a code PO833 turned it off and my cruise control began to work again anyone know what PO833 is.
Old Nov 4, 2006 | 10:42 AM
1BadBlueSS's Avatar
My cruise didnt work because the cruise button was stuck..they put a little lube on it and its worked fine.
Old Nov 4, 2006 | 01:59 PM
rnjmur's Avatar
This is a common problem with tons of posts regarding it. There are couple of things that can cause this:
1. The switch on the clutch pedal is bad.
2. The cruise control buttons or the cruise control itself is not working.
3. Most likely - you are driving with your foot on the clutch. This causes the car to throw a code because the clutch pedal always has pressure on it. You have to have the code cleared then the cruise control will work again. However if you still keep driving with your foot on the clutch the code will come right back.
Old Nov 4, 2006 | 02:02 PM
Allshot's Avatar
You are most likely riding the clutch and it activates a clutch malfunction code. I had the same problem and onstar let me know what was wrong. I took it to the dealer and they cleared the code and it hasnt happened again.
Old Nov 10, 2006 | 01:05 AM
Well I got it fixed, it ended up being a clutch adjustment. I wasnt riding the clutch at all, I was actually pulling the clutch back towards me trying to get it to work at one point lol. At least it was an easy fix...
Old Nov 10, 2006 | 03:43 AM
iso's Avatar
iso
yea, if you rest your foot on the clutch while driving it well set this off. easiest fix, don't rest your foot on the clutch pedal while driving, that's a big nono.
Old Nov 10, 2006 | 05:00 AM
TwiztedSS's Avatar
East Coast Cobalts
Just unhook your battery for a couple minutes and it will be fine
Old Nov 11, 2006 | 11:09 AM
Flash~SS2.4's Avatar
I had it too.
Take your foot and Pull your brake pedal up. It may be stuck down 1/4" and stopping the cruse from working. Thats what the problem with mine was..
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
