Share your HPtuners log screenshots...
Old Nov 21, 2006 | 08:27 AM
denny's Avatar
Here are mine from last night...
mods are on my sig. Am using the updated GM stage2 bin.
Old Nov 21, 2006 | 08:32 AM
DWK5150's Avatar
Nice but you can get rid of some of the unused parameters just to clean things up. Makes it easier to read.
For your throttle postion switch to the ETC% and itll go to 100% then.
Old Nov 21, 2006 | 08:37 AM
denny's Avatar
yeap..I know. I need to remove some useless parameters and add IAT1, IAT2 and TPS position.
Old Nov 21, 2006 | 08:41 AM
YellowLT's Avatar
I noticed your running a 2.8 and 42 injectors and only getting 15% duty cyle at 6k rpms. How can that be?
Old Nov 21, 2006 | 08:50 AM
Rodimus_Prime's Avatar
if its less than 100% Tps it may not need as much fuel at that RPM
Old Nov 21, 2006 | 08:51 AM
YellowLT's Avatar
Can't See the TPS
Old Nov 21, 2006 | 08:58 AM
exactly
Old Nov 21, 2006 | 09:16 AM
denny's Avatar
Originally Posted by Rodimus_Prime
exactly
Sorry guy's I forgot the TPS. I will do a few more runs tonight.
The first graph that screen shot I just released the gaz...thats why the injector duty is so low.
I went trew my whole log video(15 minute long) and even at wot my Injector duty cycle never went over 47% and registered 0 knock and 18-20 degree of timing advance and close to 17psi of boost.
Old Nov 21, 2006 | 09:22 AM
CTCOBALTSSS's Avatar
Hey Denny something is wrong with that IDC reading.
If you double it, it makes more sense. 94%
Edit: quick Q, what is your elevation?
Old Nov 21, 2006 | 09:29 AM
06blackg85ss's Avatar
I'll post some good ones tonight when I get my hands on my laptop
Old Nov 21, 2006 | 09:48 AM
DWK5150's Avatar
If I had my laptop Id put a couple up.
Check the IDC parameters under userdefined PIDs. See what the formula is set to cause I dont think yours is right.
Old Nov 21, 2006 | 10:57 AM
denny's Avatar
My elevation here?? Am not sure. Am in Ottawa, Ontario. Canada.
Old Nov 21, 2006 | 11:06 AM
denny's Avatar
I didnt change the formula or do I know how to access it. Doesnt it come already defined properly.
Old Nov 21, 2006 | 11:12 AM
DWK5150's Avatar
Mine wasnt right and I had to change mine. I beleive they are suppsoed to but I k now other people where theres was wrong also. To access it you need to right click on the screen then go to pids I beleive and IDC if I remember correctly is under user defined. Its something like that I dont have it right in front of me so Im going off of memory.
Old Nov 21, 2006 | 11:15 AM
denny's Avatar
Right click on the PID gives me (insert, delete, load defaults, clear table).
I have tried everything...
Old Nov 21, 2006 | 11:20 AM
patathSS's Avatar
Damn I'm an idiot. How do I save a screenshot?
Anyways, once you right click it choose insert. Open user defined PID list. Choose configure user defined. Go to Calc injector flow. Your equation should be (SENS.112)*(SENS.70)/1200
Old Nov 21, 2006 | 11:21 AM
DWK5150's Avatar
Did you click insert? Then go to user defiend and I beleive the IDC one is in there but thats not exactly what I was looking for. Of course the one day I need my laptop I didnt bring it with me. Basically you have to setup your configiuration.
Old Nov 21, 2006 | 11:22 AM
DWK5150's Avatar
THANK YOU!!! I was drawing a blank.
Old Nov 21, 2006 | 11:24 AM
patathSS's Avatar
Correction, you may have to create calc inj flow. It should use that equation for your injector duty cycle too.
Old Nov 21, 2006 | 11:34 AM
memphisr24's Avatar
Damn, I think i'm going to buy hptuners. I really need it
Old Nov 21, 2006 | 11:38 AM
Hey memphis... when you gonna meet up so I can have a go at your car man?
Old Nov 21, 2006 | 11:41 AM
patathSS's Avatar
Here's the best shot I have.
Old Nov 21, 2006 | 04:44 PM
Witt's Avatar
That Injectior Duty cycle is weird, most people have to change it the way Pat showed to get it to read correctly, however mine was already pre programmed correctly. Maybe I changed it in one of my drunken stupors and don't remember.
Old Nov 21, 2006 | 06:36 PM
denny's Avatar
That is exactly what I have!! same equation. Thats how it came when I installed it.
So if everybody is using the same equation and we are all getting different IDC with lets say the same amount of boost (16-17PSI)
....what is it, that's making are readings so different?
Old Nov 21, 2006 | 06:40 PM
Witt's Avatar
Different fueling for different tunes. Its going to base mainly on our PE values, throttle position, and map/maf readings. In short, desired A/F and engine load.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Adecker
Oct 20, 2015 09:46 PM
Delta coupe
Sep 30, 2015 08:11 AM
