My car is cursed
Old Nov 28, 2006 | 01:38 PM
bdwarr6's Avatar
My car is cursed
So today i put it up on ramps to change the oil
no biggie
last night i was tuning it drove it and brought it home
now today after i put it back on the ground it starts fine but my hptuners wont connect
i unplugged battery for 10 min still didnt work
tried half hour didnt work
now the dam engine locked me out and i have to do the security relearn
anyone ever ad issue with hp tuners not connecting saying needs key in run position and it is but wont work?
Old Nov 28, 2006 | 01:47 PM
06blackg85ss's Avatar
Yeah that happened to me the first time I used it... but I did get it to work on a full reflash I "forced" it through and all was well..
found out I accidently changed my vin number...
but you shouldn't have to do a VATs relearn on the car... unless you erased your PCM somehow
Old Nov 28, 2006 | 01:50 PM
bdwarr6's Avatar
it wont connect at all....
im trying to do the security realrn now and its not working
Old Nov 28, 2006 | 01:59 PM
bdwarr6's Avatar
ok so the battery died, hooked up a battery charger to it, and BAM no more engine disabled...
wtf i know how its supposed to work and this is far from it, i hate computers
Old Nov 28, 2006 | 02:09 PM
2K5SS/SC?'s Avatar
Have you tried talking to her sweetly yet? I mean at this point it couldn't hurt right? I hope you get it worked out man.
Old Nov 28, 2006 | 02:10 PM
bdwarr6's Avatar
dam thing just started
WTF
now to try tunerz again
Old Nov 28, 2006 | 02:19 PM
Same thing happened to my car the first time man.... your voltage was probably too low and you had a failed write... that woulda f'd it up some...
Old Nov 28, 2006 | 02:32 PM
2K5SS/SC?'s Avatar
Thank goodnes it worked itself out. Did you actually try talking to her nicely? Hell, I admit I talk to my car in hopes she responds well to my requests.
Old Nov 28, 2006 | 02:34 PM
bdwarr6's Avatar
well tunerz still doesnt work....
i found my oil leak dam camposition sensor was coming out
so i got that fixed and now my car will start once then i have to d/c the battery and r/c it then it starts again............
no i didnt talk nice to her i actually have been cussing the yellow **** all day
Old Nov 28, 2006 | 02:36 PM
bdwarr6's Avatar
im ordering a pizza since i had to call off work BAH dam cars
Old Nov 28, 2006 | 02:46 PM
Told ya man.... the yellow cobalts are cursed
Old Nov 28, 2006 | 02:53 PM
Imlikedrpepper's Avatar
Dont worry man, once all this tuning is over, and you have the car running good, it will all be worth it.
Old Nov 28, 2006 | 03:01 PM
bdwarr6's Avatar
put an if i dont blow up my garage and buy a GXP in there
Old Nov 28, 2006 | 03:03 PM
ENUFPWR's Avatar
We had something like this happen on a 04 Redline ION. (Max_boost)'s car.
Maybe this might be a simple fix.
We had no power via the OBD port. We blew the 15amp fuse for the BCM. This caused no power at the OBD port and gave us the same results... Can't connect...bla..bla..bla...
Check for power to the HPtuner cable itself via the OBD port. If you plug the cable into the OBD port and the cable has power(green light turns on) without being hooked up to the usb port on your laptop your issue is elsewhere and not what we encountered.
Hope that might help.
Old Nov 28, 2006 | 03:12 PM
bdwarr6's Avatar
thanks, that might be it, i just checked all the fused and about half of them were like 1/2 the way in WTF
this car is full of suprises
Old Nov 28, 2006 | 03:17 PM
M88ArRamadi's Avatar
When I first plugged HPT into my car I burnt out my cigarette lighter fuse. It's a 15A I think......also under the hood. Try that man
Old Nov 28, 2006 | 04:07 PM
bdwarr6's Avatar
checked all fuses and no help there
Old Nov 28, 2006 | 04:28 PM
ENUFPWR's Avatar
fuses are ok, but did you check to see if the cable powers up with it just being plugged into the obd2 port and not connected to the laptop????
If it does power up, then it's ecm related and you have a calibration recovery fail problem...software, or Hptuner cable related problem.
If there is no power to the cable, not then you have a circuit somewhere that is blown and possibly not just a simple fuse.
Old Nov 28, 2006 | 05:07 PM
bdwarr6's Avatar
with just ob2 cable box has green light
so im assuming its an ecu or tuners box issue?
The car will only start one time then you have to unhook battery and rehook it to get it to start again
Old Nov 28, 2006 | 05:13 PM
bdwarr6's Avatar
what can i do to fix it blah i emailed support for hptuners
Old Nov 28, 2006 | 06:49 PM
ENUFPWR's Avatar
Yup, unfortunately your out of luck Maybe try reloading the software or updating to the 2.14 release beta, but if you can't connect it seems like it might be a ecu/ tuners box issue. Anyways, hope they can help you.
Old Nov 28, 2006 | 06:58 PM
bdwarr6's Avatar
bah bah
this will be ecu #3
Old Nov 28, 2006 | 08:02 PM
The_Blur's Avatar
Your car is becoming quite the tragedy. I hope there's a happy ending in this for your car.
Old Nov 28, 2006 | 08:06 PM
crossed over's Avatar
if the ending isnt too happy pm me if your selling parts lol
no really tho i hope all works out for you man you put tons of work into that bitch i hope i dont go through all that this spring. but seriously if you wanna part out pm me lol
Old Nov 28, 2006 | 09:31 PM
cMw's Avatar
cMw
your car is fully of surprises
