Spark Dwell?
Old Jan 1, 2007 | 01:58 PM
Blown 4-banger's Avatar
Spark Dwell?
Ok I searched, and didn't find poo poo
Whats a good Spark Dwell to have for a car running a 2.6" pulley? I believe I'm still workin off the stock spark dwell table. The car runs fine, but when I did that search I saw Robs thread on spark dwell, but it kinda ended abruptly.
https://www.cobaltss.net/forums/show...ht=Spark+Dwell
Thanks for the help
Old Jan 1, 2007 | 03:21 PM
Old Jan 1, 2007 | 04:13 PM
TurboBlackBalt's Avatar
Spark dwell is something you normally do not need to touch unless you are having spark blowout problems.
Spark Dwell is the time the primary side of the coil is engergized. The more current you put through the primary side the larger a magnetic field is creates. When you shup off the primary ground you induce voltage into the secondary side, and this is what jumps the gap in the plug and ignites the A/F mixture.
Increasing spark dwell creates a hotter, stronger spark that is harder to blow out. However you have to remember that you only have a very small amount of time (expecially about the 5,000 rpm range).
Old Jan 1, 2007 | 05:10 PM
Thats what I was having trouble with. At around 6000-6500 I would get a HUGE miss and black smoke would come out. Spark blow out I'm sure of it, my plugs are gapped to .035. I did what it said in Robs thread, took it out for a spin, ran smoother, and no spark miss in the high rpm range
Old Jan 1, 2007 | 05:14 PM
Whats the dwell at around 6,000RPM?
Old Jan 1, 2007 | 07:12 PM
4.8976 or something like that. I made sure it wasn't more than 5 ms above 6k.
Old Jan 3, 2007 | 12:44 PM
BlackSS/SC's Avatar
So how do you know when the spark dwell is set correctly?
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
