Car won't start after HPT flash
Old Dec 31, 2006 | 05:45 PM
3fo893013L's Avatar
I just made revisions to my first tune (didn't change much, just RPM limter, Top speed and boost in 1st gear). And the stupid thing won't start. It has the Security Light on the bottom.
Went ahead and performed the Security relearn twice (as posted per spec in the help guides), pulled the negative off the battery and flashed back to stock tune. The car will not start. Any suggestions? It's aggravating.
P.S The "Power Steering" , "Low Fuel" & "Auto Lights off" keep flashing, I shut the lights off as it states in the guide.
-Mike
Old Dec 31, 2006 | 05:57 PM
Ljavy17's Avatar
are you sure u didnt use "Write entire" when you flashed. If you did, theres a chance your PCM is fried.
Old Dec 31, 2006 | 06:02 PM
yellowcobaltss05's Avatar
^^ that doesn't sound good
Old Dec 31, 2006 | 06:08 PM
06blackg85ss's Avatar
you might have changed the vin if you used another tune and did a write entire... try to reconnect and hopefully you have a full read saved... then you can reflash and all should be good... trust me... I did that the first time I used HPT myself... I was freaked for about an hour til I figured out what I did
patathSS's Avatar
The lights flashing is normal. Mine does it everytime I rewrite a tune. But like Ljavy said, it is possible the PCM fried. Did you oped a door or turn on a light or do anything while it was writing the flash? And when you do a write entire it has a much greater chance of having problems.
Old Dec 31, 2006 | 06:24 PM
3fo893013L's Avatar
It failed half way thru the first flash. That was just doing the write calibration. I tried the write calibration and it stated it was erasing entire VCM and re-writing and that failed too. It said "recovered" when doing the write calibration only again and took the flash and said it was complete. I saved the original full stock tune and reloaded it on the car and it took it but then it won't start now. It's got the security light of death. if the PCM was fried it would not doing anything period. PCM won't even accept the tune so I know that ain't it.
-Mike
Old Dec 31, 2006 | 06:35 PM
patathSS's Avatar
Did you look around on the HPT forum? It looks like some guys have had problems with writes failing and the PCM going into recovery mode. Some guys have needed to write entire after a problem like that.
Old Dec 31, 2006 | 06:36 PM
3fo893013L's Avatar
I wrote a post on HPT a few hours ago and just got replies. I gave him the info and we will go from there.
-Mike
Old Dec 31, 2006 | 07:04 PM
damn man... I"ve reflashed my car seriously over a 100 times and only had a problem the first time,,, I hope all goes well
Old Dec 31, 2006 | 07:12 PM
3fo893013L's Avatar
yah, it's dumb. If my PCM is supposedly "Fried" I suppose I can order one since it's just sitting in storage anyways. It wasn't like I was re-engineering the car, I just moved the rev limiter to 7k, limited boost in first gear and set top speed to 160 rather then 158 (not like I am EVER going to go that fast but was putzing around and this happens..
-Mike
Old Dec 31, 2006 | 08:26 PM
foff667's Avatar
my understanding is the E40 pcm isnt really fryable, generally you just do a write entire & you should be good to go. In fact there are some of the new PCM's that you currently can't do a write calibration only to for some reason.
Old Jan 1, 2007 | 01:06 AM
bigworm's Avatar
If your "write entire" fails, check your battery connections and volts. I ran into a situation like this once before when my battery died.
However, since upgrading to 2.1.14 i'm unable to do any "quick flash", only write entires...
Old Jan 1, 2007 | 12:07 PM
3fo893013L's Avatar
Battery is fine, all works but when turning over it clicks.
Old Jan 1, 2007 | 01:43 PM
zinner's Avatar
Moderator Alumni
You need talk with the support@hptuners.com people.
Old Jan 1, 2007 | 10:10 PM
3fo893013L's Avatar
i've been talking with Keith and a moderator on the forum. I think the problem eludes them. All fuses are ok and snug in the box, that's not the problem. Battery has full charge, also not the problem, I'm going to try a different laptop this weekend because on my dell laptop it keeps timing out doing a write entire (erasing the VCM and putting a new one on). Going to use my Toshiba laptop.
Also, if this doesn't work I will be towing my car out of storage come spring in shame to the dealer again. I've had nothing but problems with this car from day one. It's like it's fighting me not to mod it, drive it or let it sit for that matter.
Old Jan 1, 2007 | 11:46 PM
Joeyavhu's Avatar
If it is the same thing that happened with my Grand Am after a while, go, and stick the key to the "ON" Position, let it sit for 10 minutes and the Security light will go off. Then, turn the key to the Off, and then start the car. That worked with my Grand Am when it did that, so, hopefully, since it is part of the GM Security System (PassLock II or something along those lines) it should work because that recodes the starter to match your key.
Old Jan 2, 2007 | 12:07 AM
3fo893013L's Avatar
I really wish it was that easy. I've already done that. The security light never goes away.
Old Jan 2, 2007 | 12:20 AM
Joeyavhu's Avatar
Ohh.. I wish I could help. I remember how long I searched when my car did that for an answer. I hope everything works out though.
Old Jan 2, 2007 | 12:21 AM
Joeyavhu's Avatar
Will the dealership look at it?
Old Jan 2, 2007 | 12:26 AM
3fo893013L's Avatar
The car sits about an hour north of my normal dealer. I will take it only there. I can get it towed but I can say with certainty that 99% my car will get scrwed by the tow truck. taking it to dealer is last option if I cannot figure it out.
Old Jan 2, 2007 | 12:27 AM
3fo893013L's Avatar
Thanks for the advice though
Old Jan 2, 2007 | 08:11 PM
Joeyavhu's Avatar
Yea, no problem. At least I can say I tryed.
Old Jan 3, 2007 | 08:34 AM
3fo893013L's Avatar
Update: I got the car running, a write entire was needed but the problem followed me when I tried to tune another members car, we had another set of cables to see if that was the problem that interface from the laptop to the little hp tuners box, and a cable from that to the ODBII Port but swapping cables didn't help, neither did my other laptop. I think I have a defective tuning box. It works when IT wants to.
-Mike
Old Jan 3, 2007 | 08:36 AM
CTCOBALTSSS's Avatar
Good to hear you got yours running but that whole situation sucks.
Hope you get it all worked out.
Old Jan 3, 2007 | 09:05 AM
3fo893013L's Avatar
Thanks. I hope I can get a replacement soon.. I write them on the HPT forums to help. Hopefully they pull thru.
-Mike
Here is a reference to my inital issue with screen shots and letting them know what's going on
http://www.hptuners.com/forum/showth...7508#post67508
