North Pacific WA and OR
High Octane Fuel
Old Mar 11, 2007 | 06:48 AM
aja342's Avatar
High Octane Fuel
Anyone know where I can get some high octane fuel in the Tacoma area? Going to need some good fuel for the Dyno day the 17th and do not want to use octane booster.
Old Mar 11, 2007 | 04:07 PM
sensesfail99's Avatar
gas station in auburn called the pitstop.... ill try to find the address for you form the guys at work tomorrow. you can get like 101, 110 and 114 i think.... but its like 4 or 5 bucks a gallon... id only recommened getting like half a tank.... but do what u want :-p
http://forums.evolutionm.net/showthread.php?p=3999389
try joining the forum on this link and ask them.... they will probably tell you the directions to it. one post said something about it being in the 6 dollr range
Last edited by sensesfail99; Mar 11, 2007 at 04:07 PM. Reason: Automerged Doublepost
Old Mar 11, 2007 | 04:46 PM
SwizzDSMSS's Avatar
No, there is a 76 station off of Auburn Way and 15th(really easy to find). It has Trick 101 unleaded outta the pump. It is $6.25 a gallon. You cant get the leaded cause it will **** up your cat. So the 101 is only way to go.
Old Mar 11, 2007 | 05:38 PM
aja342's Avatar
Trick 101 is good stuff. I am just going to get a 2gal can or so for the dyno. Thanks for the info.
Old Mar 11, 2007 | 08:49 PM
how many times u goin to run the dyno? Id do once without the fuel and then once with it... that way u know what ur car is really sitting at....
Old Mar 11, 2007 | 08:58 PM
aja342's Avatar
I just want a lil good gas to be on the safe side. Makes me feel better till I get a A/F meter.
Old Mar 11, 2007 | 09:01 PM
R&C_rallySS's Avatar
That is a great idea. Bring a small 2 gallon gas container. Fill that bad boy up and after your first run on low fuel put a gallon of the high high test in. Good luck, will look forward to seeing what you pull
Old Mar 11, 2007 | 09:05 PM
aja342's Avatar
Hey Swizz...Are you the Cobalt that Jason (LFSADRG) keeps telling me about. Either way, nice car.
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
