Cometic 2.0 LSJ Head Gaskets Now Available!
The same company that helped us bring you the outstanding MLS (multi-layer steel) gaskets for the 3800 now has helped us bring you an MLS gasket for your supercharged Cobalt or ION. We worked hand in hand with Cometic to bring a 2.0 specific MLS head gasket to the masses including sending in stock head gaskets for analysis and we are proud to be the first vendor to offer it to you.
Plainly stated, these are the best head gaskets money can buy. Two viton coated outer embossed spring steel layers with one uncoated stainless steel inner layer to provide support to the gasket. These gaskets are manufactured with a bore size of 87mm to accommodate stock bored LSJ motors. Thickness is .027.
This gasket was designed specifically for the 2.0 supercharged LSJ motor. It is not a 2.2 naturally aspirated head gasket as others may sell.
Sep 28, 2015 12:51 PM
