Getting my SS into reverse
Old Sep 9, 2005 | 02:14 AM
Toronto SS's Avatar
I'm just curious if anyone else occasionally can't put their SS into reverse.
Wanna know whether this a lock out problem on my shifter or a common cobalt annoyance.
It does eventually allow me to put it in reverse after a dozen or so tries.
Old Sep 9, 2005 | 02:18 AM
DC52NV's Avatar
you are at a complete stop when attempting to put it in reverse right?
Old Sep 9, 2005 | 02:24 AM
Toronto SS's Avatar
Yes I am. I parallel park out front of where I work every night on level ground, so you can imagine how annoying temporarily losing reverse can be
Old Sep 9, 2005 | 02:26 AM
DC52NV's Avatar
hmmm, yeah that would be annoying. i say take it to the dealer and have them look at it.
Old Sep 9, 2005 | 02:27 AM
winger46146's Avatar
i have the problem with my truck some time. what i have to do is put it in frist then try putting into reverse
Old Sep 9, 2005 | 02:30 AM
betterthanbad's Avatar
Stop ........Rev enginge a little.......Clutch in....................Set it in reverse..............Rev the engine a little.....let out the clutch and it should be fine.......
Old Sep 9, 2005 | 02:33 AM
Toronto SS's Avatar
Yeah, I already do that to stop it from grinding.
Old Sep 9, 2005 | 02:37 AM
Toronto SS's Avatar
The problem is that I can't physically get the shifter into reverse.
Old Sep 9, 2005 | 02:38 AM
Just put the clutch in and give it a little rev. (I MEAN A LITTLE) and then let it out......it works every time. Almost like resetting everything. Don't ever push it if it doesn't want to. If it ever doesn't work I just fumble with the shifter a little with the clutch in and rev a little and everything works!!!!!!
you said it won't work......................put it in neutral.....rev a bit and then ease it in reverse. and try again.
Old Sep 9, 2005 | 02:39 AM
Toronto SS's Avatar
I'll give it a whirl.
Old Sep 9, 2005 | 02:44 AM
So...........................what happened?????
Old Sep 9, 2005 | 03:36 AM
Toronto SS's Avatar
I'll give it a whirl next time it happens, it only hapens two, maybe three times a week.
Old Sep 9, 2005 | 08:58 AM
Ern's Avatar
Ern
Pull up with your pointer finger and middle finger on the ring lock under the shift knob.
Old Sep 9, 2005 | 01:44 PM
Toronto SS's Avatar
How do you know those arent the fingers I'm already using? And what does it matter what fingers I use?
Old Sep 9, 2005 | 02:04 PM
orangepower's Avatar
it doesn't matter, it happens to me sometimes, i just put it into neutral, let out the clutch, wait a sec, then firmly depress the clutch all the way and it works for me then. My car knows who's boss. She treats me right, she gets the good stuff, 91 octane. Oh yeah
Old Sep 9, 2005 | 02:32 PM
xavier102772's Avatar
I figure it's one of two things if you are having so much trouble putting it in reverse:
a. You're a retard and don't know how to drive standard.
b. There's something wrong with the car.
I assume you're not a retard and know how to drive standard, so maybe you better take it in to get it looked at.
Old Sep 9, 2005 | 05:42 PM
Ern's Avatar
Ern
No it dont matter rofl, and im refering to the ss model with the reverse ring lock under the shift ***. You never said you tried that so I assume you didnt know it was there. Now if it wont go in reverse and youve done that much then Im sorry I cant tell you there cuase I dont drive your car.
Old Sep 9, 2005 | 10:31 PM
Woodio's Avatar
My car did this to me today trying to back out of the parking garage at work. Just put it into 1st gear and go back down to reverse and it went in gear. I think the problem is caused by parking it in 2nd gear doesn't trigger the lockout or something. I park on flat ground so i always forget to park it in the lowest gears. I looked in the manual and it says to park your car in reverse, maybe the lockout gets screwed up when you park it in another gear and shut it off...
Old Dec 9, 2006 | 05:45 PM
g5mike's Avatar
maybe you are in the wrong gear
Old Dec 9, 2006 | 05:46 PM
Allshot's Avatar
Old Dec 9, 2006 | 05:47 PM
Toronto SS's Avatar
raiders of the lost threads here
Old Dec 9, 2006 | 05:49 PM
Toronto SS's Avatar
I am aware thank you.
Old Dec 9, 2006 | 05:54 PM
Allshot's Avatar
Old Dec 9, 2006 | 05:56 PM
Woodyr007's Avatar
Mine never goes in when its cold, have to take it out rev and put back iun too
Old Dec 9, 2006 | 07:43 PM
SStud's Avatar
Mine started doing this after i had the CM FX400 put in. (I'm having problems with this clutch so my situation might not be related.)
