Need Help!!!! Loss of Power for no reason!!!
Old Apr 21, 2007 | 11:48 AM
Lithium's Avatar
So, if you tried helping me before, thx, but the problem is yet to be solved. Did a bunch of tests, tried a few different things, put it back on the dyno and still have the same loss in HP.
I need HELP guys!!!!
Myself and my tuner are completely stumped.
Here is the most recent outcome via an email to HPtuners via my tuner at SpeedDreams:
Have a 2005 Cobalt ss/sc that's way down on power. Car ran great for months, came in last week and dynoed 50 wheel horsepower less all of a sudden. Vehicle passed compression, leak-down and injector flow testing. Tune is still where I want it on the timing/af.
So far this is what has been tried to fix the problem:
-Exhaust has been upgraded to a lt header and catless 3"
-Spark plugs have been switched for 1 heat range colder plugs
-Supercharger has been verified to produce the same 15.5 psi
-Torque is only off by 10-15 ft. lbs.
-IAT's appear to be within range and heat exchanger is flowing coolant
-Hp curve is significantly affected being 5-19% lower at all rpms
Here is the log from our last try on the dyno recorded on HPTuners:
http://www.turboninjas.com/gallery/d.../jjrun022_hpl?
Here is the actual dyno results: blue is original 262whp dyno, Red is current:
I'm really at a loss here guys. Other than the loss of power the car seems normal. I don't know what to think or where to go from here.....
Old Apr 21, 2007 | 06:55 PM
CobaltBurst's Avatar
maybe they had the dyno resistence set wrong....
Old Apr 25, 2007 | 05:49 PM
-Jayson-'s Avatar
yeah if you cant notice a loss in power, id guess they had the dyno setup wrong at one point or another. 50HP would be easily noticeable.
Old Apr 25, 2007 | 06:03 PM
chevysssc's Avatar
262 hp is a lot at the wheels i know a cobalt with 20 psi and hes putin down 265 i think they set the dyno wrong your first pass like he said that would be extremly noticeable
Solaris99
28
Mar 15, 2017 01:22 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
Stuff
Oct 1, 2015 05:47 PM
Sep 28, 2015 12:51 PM
