Intake for 2.4
Old Sep 29, 2005 | 04:18 AM
twiztedtrav's Avatar
Intake for 2.4
Just wondering if anyone has fit an intake for the 2.2 on a 2.4, I was lookin at them today at a car lot and they appear to be exactly the same. Anyone know???
Old Sep 29, 2005 | 09:04 AM
RaineMan's Avatar
That's a question I have been doing my best to determine. I haven't tried it so far, but I have thought about contacting some companies that make the 2.2L intake and asking their opinions on the matter. As far as I know the throttle body and intake system are exactly the same.
Old Sep 29, 2005 | 02:18 PM
97cavie24ls's Avatar
id think the 1's for the 2.2 would fit the 2.4
i know everyone that makes 1's for the cavaliers use the same size tubing for the 2.2 and 2.4
so i dont think that should matter on the 2.2 eco and the 2.4 eco
Old Sep 29, 2005 | 03:48 PM
brentil's Avatar
Here are the images of the two engines from the Cobalt. There appears to be a slight difference but I'd say they're within a half inch of each other location wise at most, and appear to have the same diameter and lip depth.
2.2L
http://media.gm.com/us/powertrain/en...0COB%20LoR.jpg
2.4L
Old Sep 29, 2005 | 04:37 PM
yeah the intakes do look different
but very close to each other
Old Sep 30, 2005 | 08:11 AM
RaineMan's Avatar
Good images.... just what I've been looking for
Ya know.... it seems to me that with the throttle body in that location.... this thing would do wonderfully with a short ram-air setup. It'd just be the matter of relocating the MAF sensor to just before the throttle body. Short piece of tubing... cone filter.... and there ya have it....
Comments??
Old Sep 30, 2005 | 08:29 AM
3fo893013L's Avatar
The 2.4L throttle body looks bigger... I know the 2.2L utitlizes a 60mm single thorttle body. I think the 2.4 uses a 65mm? who knows... good luck doing some riggin if you can't wait for intake
Old Sep 30, 2005 | 09:00 AM
Deaf_Dog's Avatar
You guys see a difference between those two pics. I definately overdue for an eye exam.
Old Sep 30, 2005 | 12:38 PM
look on the left on the intake , the 2.2 has mounting studs on it left over from the early ion's and vue(i think) that is where the pcm was mounted
also it looks like the port paths changed slightly , also the tb angle looks a little different
Old Oct 11, 2005 | 02:05 PM
vic_romano's Avatar
Slight highjacking of this thread...does anyone know when K&N is going to release an intake for the 2.4 or if there are any out there floating around yet?
Old Oct 11, 2005 | 02:19 PM
phxSS's Avatar
The 2.4 TB looks to be a little higher on the intake runner than the 2.2
Old Oct 11, 2005 | 04:11 PM
brentil's Avatar
Fujita has an intake in the works for the 2.4L VVT ECOTEC in the Solstice that should be out in a couple months. This kit of course wont fit in the Cobalt, but once the specs are out you'll know for sure if a 2.2L intake will fit on a 2.4L if no one else has figured it out yet by then. Hopefully that means they'll also make a Cobalt version as well though.
Old Oct 11, 2005 | 10:59 PM
RaineMan's Avatar
From what I've seen... Gravana is apparently going to have an intake for the 2.4 out in december.... check their website....
Old Oct 12, 2005 | 10:19 AM
swatthefly's Avatar
i just got an email from kappasphere about their website, and didnt they have an intake on there? that should be for the solstice, but at least you could check the TB
Old Oct 12, 2005 | 10:50 AM
vic_romano's Avatar
thanks for the info it's greatly appreciated!
Old Oct 12, 2005 | 01:29 PM
brentil's Avatar
Yes, a Fujita intake.
Old Oct 13, 2005 | 02:23 AM
frankmckeever's Avatar
...wondering this myself. I'm also wondering if the headers are the same (god that would be nice).
Old Oct 13, 2005 | 08:38 AM
RaineMan's Avatar
I would certainly volunteer to use my SS 2.4 as a guinea pig for the intake. I've considered ordering one for a 2.2L before... just dunno about issues returning it if it dosen't work... heheh.
Old Oct 13, 2005 | 09:38 AM
MikeSS's Avatar
I'm just going to make myself an intake like usual. It looks ugly, but $30 canadian is a lot better then $400
Old Oct 13, 2005 | 09:59 AM
RaineMan's Avatar
Mike, exactly how are you planning to mount the MAF sensor onto the custom intake? That is really the only thing causing an issue in my mind as far as a custom job goes.
Old Oct 13, 2005 | 10:12 AM
oaklandmr's Avatar
Id love to see and intake for these motors. I think it would open up alot of HP as well as gas milage
Old Oct 13, 2005 | 12:05 PM
brentil's Avatar
I'm hoping we see a larger increase in performance with the 2.4L VVT then the 2.2L engines from intake/exhaust. Our cumbustion chambers are a total of 8.3% larger then the 2.2L so it takes a bit more air to completely fill them then the 2.2L. So if the system is being restricted already at 2.2L then our 2.4Ls would be restricted even more. Especially if since the redline is higher too in different versions of the 2.4L VVT depending on what car it's in then the 2.2L.
Old Oct 13, 2005 | 05:34 PM
MikeSS's Avatar
dremil out a rectangle, and install in the intake with some rubber surrounds. Then use the pre-existing screws on the MAF and some metal wire to secure it in place.
Old Apr 21, 2010 | 01:11 AM
Ion's Avatar
Ion
Yea. I bought th Weapon-R and
1. Its trash. It looks fugly and as soon as its on, my rpm hovers around 1700. It won't go down.
2. I bought the 2.2, which is listed as 2.4, but in reality is not. It connects with a 2.5 piece, and the throttle body is definitely larger. I had to take a rotozip to the rubber connector to even get it to fit. Do yourself a favor and just buy the one designed for the 2.4 R&D is done for a reason.
Old Apr 21, 2010 | 10:11 AM
Chuck's Avatar
Not to be mean..but this thread has been dead for almost five years...lol.. How did you even find it..I mean there are over 100,000 other threads of air intakes...
oh no..I just bumped the thread to the top..lol.. crap!!! oh well.. I guess thats what makes it
