I cant get the head light casing out
Old Jun 9, 2007 | 05:50 PM
kingmike06's Avatar
I just got my extreme vision 8500K blue light of off ebay and im tring to install them, but i cant get the casing out. I unscrew the two screws but when i try to pull the casing out it would come out. Also do I need anything else for these lights, i dont wanna burn the plastic?
Old Jun 9, 2007 | 05:56 PM
c0ld29's Avatar
im semi-confused.. is it just bulbs? all you do is turn the black piece counter clockwise i believe and it undoes, then you pull the old bulb out.
Or is the entire headlight getting out your problem? If so, undo the 2 bolts, also pop off all of the little black taps. Then pull the bumper towards you carefully and pull the headlight out at a slight angle.
Old Jun 9, 2007 | 05:59 PM
DTM2188's Avatar
Yea, like said above, you have to pull out the black plastic screw things that holder the bumper/grill on as well so that you have enough room.
Old Jun 10, 2007 | 08:55 AM
Brian's07SS's Avatar
^ what they both said..Once you get them out the first time its a piece of cake if yo have to do it again..I had the manual n everything when I changed my bulbes the first time. I looked like an ass out in the cold hahaha..
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 28, 2015 12:51 PM
